2008 700 sci dying out >
Old 08-23-2010 | 01:05 PM
Default 2008 700 sci dying out
Hey guys Im trying to help a friend out that has a 2008 cig with twin 700sci engines ,the port engine will die when going through a no wake,starts right up and then runs fine,we switched the iac and didnt help.we checked the min idle setting and its fine,checked tps reading which was fine,no stored codes,last time it happened we could tell it was going to die because we felt the engine load up like it was flooding out,tryed accelerating in gear and had a hard time getting over 1800 rpms ,shut the engine off and restarted and then was fine,
any ideas? Thanks
boatnt is offline
Old 08-23-2010 | 02:51 PM
Leaking header? Fouled plugs?
Back4More is offline
Old 08-23-2010 | 03:19 PM
any ideas? Thanks
bad anticipation switch at the shift box in the motor box mine did the same thing-- not good especially when trying to dock- change both switchs out they were not that expensive
robert246 is offline
Old 08-24-2010 | 07:12 AM
No neither,thanks
boatnt is offline
Old 08-24-2010 | 07:13 AM
Thanks for the info,check your PM
boatnt is offline
Old 09-13-2010 | 06:49 PM
Robert Thanks for all your help,you pointed me in the right direction.
Heres an update
If I unplug the Interuptor/anticipation switch and drive the boat with it unplugged the boat runs great and does not die.
I replaced the switch and the boat started dieing out as soon as we pulled out of the boat lift,I unplugged the switch and the boat then runs great,
so my question is what is the correct way to adjust the setting on the switch? I backed it out and on 3 times out it has died one time,better but not 100%
what would happen if I left the switch unplugged? would I hurt the ECU?
Thanks for any help.
boatnt is offline
