polishing canopies on 32 skater ???? >
Old 08-23-2010 | 06:55 PM
Question polishing canopies on 32 skater ????
does any body know what to use to polish 3/4 canopies, there very hard to see thru , and have a haze on them ... do i use a high speed buffer , with compound? ive never worked on any ...any help would be great THANKS
PARKER RABE is offline
Old 08-23-2010 | 07:18 PM
http://www.novuspolish.com/
skaterdave is offline
Old 08-23-2010 | 07:59 PM
Novuspolish works great and wett sanding & buffing will make them look like new again
good luck
Old 08-23-2010 | 08:20 PM
what grit sand paper ? 80
Old 08-23-2010 | 09:23 PM
80 Yikes, no no no. more like 1500
tzrider is offline
Old 09-01-2010 | 07:18 AM
Are they polycarbinate, or lexan? There is a huge diff. in material, polycarbinate is almost impossible to polish due to burning thru the layers. You can sand them & clear coat them for long term appearance.
Slug-ger is offline
Old 09-01-2010 | 07:50 AM
Might want to call Skater. Last time i was out there they had tons of those, and with everyone going with wrap around windshields, they might give you a deal on a new set.
Hustler40 is offline
Old 09-01-2010 | 08:38 AM
1500/2000/2500 grit paper & a 3000 pad
Old 09-01-2010 | 08:54 AM
Try Texstars http://www.texstars.com/
They manufacture the original f-16 canopies. I believe that CcanDo used them to refinish theirs: http://www.offshoreonly.com/forums/g...oration-9.html
"The canopies had been set to the original manufacturer (TEXSTARs) to be reground and coated back to original."
If you don't mind, please post your results after contacting them.
Dueclaws is offline
Old 09-02-2010 | 08:33 PM
Lauderdaleboats's Avatar
There is a kit called Micromesh which is ideal for the PC canopies
Lauderdaleboats is offline
