Difference between 454 and 502
What is the easiest way to tell the difference beteween a 502 and 454 when in the boat. Looking at a boat that is supposed to have a 502 but not sure and want to check it out tonight
also i dint know if they all had this but mine have a 8.2 casted on the side of the block next to the freeze plugs.
On the back by the bellhousing but usually doesnt survive that long. Is a mercruiser engine or a custom. A merc motor will have it on it or at least you can look it up. Other than that you will have to pull the casting number and look it up.
Gen 4 502's have a mechanical fuel pump on the block. Gen 4 502's also have a chevy bowtie on one side of the block....hense, a Bowtie block! Gen 5 and 6 blocks need to run electric fuel pump or off the sea pump.
[QUOTE=kreed;3189572]Gen 4 502's have a mechanical fuel pump on the block. Gen 4 502's also have a chevy bowtie on one side of the block....hense, a Bowtie block! Gen 5 and 6 blocks need to run electric fuel pump or off the sea pump.[/QUOTE
Gen 5 454/7.4 also do not have the casting for block mounted fuel pump. At least my 7.4 doesn't.
