Oil Filters
Old 08-24-2010 | 02:58 PM
Default Oil Filters
Anyone know a place in the USA to buy FRAM RACING HP4 filters by the case?
I am paying over 20 bucks CDN in Toronto.
I want them by the case.
ar15meister is offline
Old 08-24-2010 | 04:18 PM
CIG3's Avatar
I'd look into Wix filters. In my opinion thye are much better than Fram.
http://www.wixfilters.com/filterlook...sp?Part=51060R
Part Number: 51060R
UPC Number: 765809129269
Principal Application: Racing Applications Only
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.170
Outer Diameter Top: 3.600
Outer Diameter Bottom: Closed
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Anti-Drain Back Valve: Yes
Max Flow Rate: 28 GPM
Nominal Micron Rating: 61
Gasket Diameters
Number O.D. I.D. Thk.
Attached 3.444 3.100 0.260
Close Window
CIG3 is offline
Old 08-24-2010 | 04:26 PM
I wouldn't use a Fram if they paid me!
07DominatorSS is offline
Old 08-24-2010 | 04:27 PM
cigrocket's Avatar
I agree Wix or K&N, Fram really isn't doing anything
cigrocket is online now
Old 08-24-2010 | 05:00 PM
Kelly O's Avatar
Go to : www.Filter1.com Large Distributor of WIX Filters, cross that Fram number to a WIX Racing filter 51060R.
They will hook you up, part of our family's business, they do ship internationally, specialize in case quantity sales.
Kelly O is offline
Old 08-24-2010 | 05:27 PM
I agree 100%. WIX, or K&N, IMO are the best, but if I were stuck with a autopart store brand I would get a Purolator.
Cut them open and check out the guts if you think that they're all the same... They're not!
wjb21ndtown is offline
Old 08-24-2010 | 07:33 PM
Advanced Auto Parts stores usually stock 2 HP4 filters at a time for about $8.50 a piece
JoeD is offline
Old 08-24-2010 | 09:21 PM
outriggers's Avatar
I was told the Fram racing filter is different. I will cut both open and take a look.
Doug
outriggers is offline
Old 08-24-2010 | 09:35 PM
You should defintely be using WIX racing filters (or even the regular WIX filter). They are by far the best for our boats. Fram is not in the same hemisphere.
34Mach1 is offline
Old 08-25-2010 | 08:58 AM
thanks guys. The engine guys told me the HP4 Fram Racing was fine to run.
I used to run WIX Racing.
