Livorsi Blow-Out Extravaganza!!
Old 08-24-2010 | 07:58 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Default Livorsi Blow-Out Extravaganza!!
ALL GAUGES MUST GO! OUR SHELVES ARE UNDER TOO MUCH PRESSURE! SALE PRICES ARE FOR THE LIVORSI WATERPROOF STYLE GAUGES THAT MOST OF YOU CURRENTLY HAVE IN YOUR BOATS/TOYS THAT ARE NO LONGER AVAILABLE FROM LIVORSI!
PLATINUM FACE / PLATINUM RIM
2 1/16"
GIFLPLPL Fuel Level $30.80ea (4)
GIFPPLPL Fuel PSI 0-15 Elect $37.80ea (9)
GIFP90PLPL Fuel PSI 0-90 Elect $37.80ea (5)
GIVMPLPL Volt $30.80ea (4)
GIOTPLPL Oil Temp $30.80ea (10)
GIOPPLPL Oil PSI 0-100 $30.80ea (6)
GIWTPLPL Water Temp $30.80ea (4)
GITMMPLPL Trim Meter Mercury $30.80ea (7)
GIHMPLPL Hour Meter $48.30 (2)
GMFPPLPL Fuel PSI 0-15 Mech $61.60ea (8)
GMFP100PLPL Fuel PSI 0-100 Mech $61.60ea (5)
GMOPPLPL Oil PSI 0-100 Mech $61.60ea (3)
GMBPLPL Boost 0-35 Mech $61.60ea (4)
3 3/8"
GL8000PLPLV10 8000 Tach for V-10 $204.30ea (3)
GW8000PLPL 8000 Tach $160.30ea (1)
GPS80PLPL 80 MPH GPS/Kit $184.00ea/$399.00kit (4)
GPS100PLPL 100 MPH GPS/Kit $184.00ea/$399.00kit (3)
GPS120PLPL 120 MPH GPS/Kit $184.00ea/$399.00kit (4)
GPS140PLPL 140 MPH GPS/Kit $184.00ea/$399.00kit (3)
GDS80PLPL 80 MPH Dry Speedo $88.00ea (1)
GDS100PLPL 100 MPH Dry Speedo $88.00ea (5)
WHITE FACE / WHITE RIM
2 1/16"
GIFP60WW Fuel PSI 0-60 Elect $37.80ea (1)
GIFP90WW Fuel PSI 0-90 Elect $37.80ea (1)
GIWTWW Water Temp $30.80ea (5)
GIOPWW Oil PSI 0-100 $30.80ea (5)
GIWPWW Water PSI 0-35 Elect $30.80ea (3)
GITMMWW Trim Meter Mercury $30.80ea (4)
3 3/8"
GL8000HWW 8000 RPM Tach w/ Hour $188.30ea (1)
GW8000WW 8000 RPM Tach $174.30ea (1)
GL8000WWV10 8000 RPM Tach V-10 $204.30ea (2)
PLATINUM FACE / CHROME RIM
2 1/16"
GIFLPLCH Fuel Level $30.80ea (4)
GIFPPLCH Fuel PSI 0-15 Elect $37.80ea (2)
GIFP90PLCH Fuel PSI 0-90 Elect $37.80ea (5)
GIVMPLCH Volt Meter $30.80ea (4)
GIOTPLCH Oil Temp $30.80ea (4)
GIOPPLCH Oil PSI 0-100 $30.80ea (4)
GIWTPLCH Water Temp $30.80ea (3)
GITMMPLCH Trim Meter Mercury $30.80ea (2)
GIHMPLCH Hour Meter $48.30ea (2)
BLACK FACE / BLACK RIM
2 1/16"
GIFP60BKBK Fuel PSI 0-60 Elect $37.80ea (1)
GIFPBKBK Fuel PSI 0-15 Elect $37.80ea (1)
GIVMBKBK Volt Meter $30.80ea (1)
GIOTBKBK Oil Temp $30.80ea (2)
GIWPBKBK Water PSI 0-35 Elect $37.80ea (2)
GIOPBKBK Oil PSI 0-100 $30.80ea (2)
GIOP80BKBK Oil PSI 0-80 $30.80 (4)
GIHMBKBK Hour Meter $48.30ea (2)
GITMMBKBK Trim Meter Mercury $30.80ea (1)
GMPYDBKBK Pyro Kit $130.40ea (1)
ALL OTHER LIVORSI GAUGES AVAILABLE FOR GREAT PRICES! MUST CALL W/ PART NUMBER FOR THESE SPECIALS!
TEAGUE CUSTOM MARINE
661.295.7000
www.teaguecustommarine.com
teaguecustommarine is offline
Old 09-17-2010 | 10:51 AM
Default Still Have Gauges!
Still have gauges on the shelf people! Get them now, install them this winter, and be ready for the spring!
661.295.7000
Old 10-02-2010 | 10:48 PM
hullofjustis's Avatar
Default gauges
In need of gauges for twin engine set up [email protected]
hullofjustis is offline
Old 10-06-2010 | 01:31 PM
E-mail sent!
Old 10-12-2010 | 09:41 AM
bigboat28's Avatar
Also considering replacing gauges on a twin set up. [email protected]
bigboat28 is offline
Old 10-13-2010 | 09:21 AM
Default PLATINUM FACE / PLATINUM RIM guages
I want to replace all my guages on my '94 27 Fever single engine. I notice that you have everthing I need in the platinum/platinum guages except for the Water PSI and a Depth Finder. What are the chances of getting these in the same colors? Also...I want to go with the 80MPH GPS including antenna...what will that run?
Thunderstruck27 is offline
Old 10-14-2010 | 10:50 AM
Give us a call! I will work it out for you, and get the other matching gauges. I do have the depth finder on the shelf! -Eric
661.295.7000
Old 10-14-2010 | 10:52 AM
email sent!
Old 06-22-2015 | 10:37 AM
Default Do you still have this model gauge available? GL8000HWW 8000 RPM Tach w/ Hour $188.3
2 1/16"
3 3/8"
2 1/16"
3 3/8"
2 1/16"
2 1/16"
661.295.7000
gallagr1 is offline
Old 08-16-2017 | 09:08 PM
Looking for twin engine gauge sets Chrome or stainless rim/white or platinum face.Whats the best you can do?
Ralph
[email protected]
ralphspa is offline
