what rpm is ok? >
what rpm is ok?
what rpm is ok?
Old 08-26-2010 | 12:51 PM
Default what rpm is ok?
i have a 454 carb in my 272 baja, what rpm is ok to run ? i had it full throttle the other day in calm waters and it went to 6k rpm maxed, in ruff waters i was maxing about 5rpm only at full throttle, i was told to never go over 4500rpm is this correct? thax jim
delly is offline
Old 08-26-2010 | 12:52 PM
oh its got a bravo 3 also
delly is offline
Old 08-26-2010 | 01:53 PM
454 7.4L or 454 Mag? What prop you running? If you went to 6k your rev limiter is disabled. You shouldn't be able to rev it over 5200 regardless
Irishtornado is offline
Old 08-26-2010 | 02:25 PM
obnoxus's Avatar
Charter Member #1171
Older carb motors wont have a rev limiter.
I wouldnt go over 5200 if its a mag,,,, less for the 300/330 hp
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 08-26-2010 | 03:11 PM
Dock Holiday's Avatar
Charter Member #34
4800 to 5000 RPM
Must be a good solid motor if you got 6K rpm.
Dock Holiday is offline
Old 08-26-2010 | 04:17 PM
Custom Interiors & More
Make sure your Tach is set for 8 cylinders on the back of the gauge.
XT
XT-Innovator is offline
Old 08-26-2010 | 08:07 PM
its just the 7.4 454, as far as prop,im not sure, where would i find that info is it engraved on them? its a bravo 3 with dual props.
delly is offline
Old 08-26-2010 | 08:09 PM
well can you pin the throttle on these boats? because 5k rpm i get without having the throttle all the way forward,theres still room to go more,thats why i ask..
delly is offline
Old 08-26-2010 | 08:16 PM
rchevelle71's Avatar
Either your tach is not set on 8 cyl., or you need bigger pitch props.
rchevelle71 is offline
Old 08-26-2010 | 08:24 PM
I think your tach is off.
jeffswav is offline
