3 blade vs 4 blade prop >
Old 08-26-2010 | 03:43 PM
Default 3 blade vs 4 blade prop
so this may be a dumb question but I have a 3 blade 25p prop what would I gain if I went to a 4 blade 25p prop. someone was trying to sell one for $300 on CL.
nbishop57 is offline
Old 08-26-2010 | 04:31 PM
More transom lift. But more is not always better. It depends on the application. Need more info. If your boat came w a 3bl, I'd prob. stay w that. The manufacture ususlly spends lots of money on research on what works best. One of the pros on OSO will chime in w more info.
Greenkeeper is offline
Old 08-26-2010 | 04:51 PM
You will lose about 300-400 rpm at WOT with the same pitch. That can be fixed by getting them labbed. You will most likely have better cruise speed.....less prop slip. May loose a little at top end. I went from 4 blade to 5 blade. Had 28% slip at cruise with 4 blade. Had 13% slip at cruise with 5 blade Maxximus props. Since I spend 99% of my time cruising, I like more blades myself. Better gas milage.
UrbanDisturbance is offline
Old 08-26-2010 | 05:33 PM
what kind of boat/power do you have. i figured over 25% slip at cruise also and keep wanting to try a 5 blade but keep putting it off. did it hurt your top speed? what size 4 blade to 5 blade switch did you make?
specialk is offline
Old 08-26-2010 | 05:39 PM
Depends on the boat. I have found if you want speed the Mirage is the best, as long as you can get on plane. If you tube, ski and make a bunch of tight turns the Bravo 4 blade or Hydro 4 blade work well.
Where do you live in STL and were do you boat at?
jeffswav is offline
Old 08-27-2010 | 01:25 AM
It depends on what props you are talking about. There are tons of brands and types of both 3 blade and 4 blade props.
Griff is offline
Old 08-27-2010 | 06:51 AM
I have a 1994 Cigarette TOP GUN. It weighs 11500lbs with no fuel. Twin 600hp 502's. I originally had 4 blade 26 pitch clever style Hydromotives, which I still have and are for sale if anyone is interested. I was underpropped after new engines were built. I had at least 28% slip at cruise, maybe more. I would hit my rev limiter in seconds. I bought non-labbed 28 Pitch 5 Blade Maximus props. They feel 3 times more heavy than the Hydromotive. At 3200rpm, I had 13% slip with the Maxiumus, but my pitch was off. I went from 5500rpm to 4500rpm at WOT. I had them labbed by a local company and I am back at 5500rpm, but now have 22% slip at cruise. I still need a little more cup to drop it down. I'm not too happy about the Lab job that cost me $1000.
I wish I would have called BBlades.
I think they have a demo program or something.
I think I lost some top end, but I can't confirm.
By the way, the 5 Blade Maximus will create a lot of stern lift and the only weigh to change that is by getting them labbed, which I think creates SLIP.
Old 08-27-2010 | 07:06 AM
Urban, you gain 1000 RPM just by labbing the props? Doesnt sound right. Usually gain 2 to 400 RPM when labbed properly. Sounds like your just slipping. I would call Brett ar BBlades......
kreed is offline
Old 08-27-2010 | 07:18 AM
Thanks for the info I think I am going to stay away from the 4 blade I don’t do a lot of tubing or skiing right now b/c my kids are still to young and I don’t want to lose any of my top end speed. JeffswavI live in Wentzville, I do all of my boating at the Lake of the Ozarks.
Old 08-27-2010 | 07:24 AM
They changed the Maximus pitch from 28 to 25-26. The first time around, it slipped at 28% at cruise. They added more cup and now it is at 22% slip at cruise. I need to test my WOT to see if I need anymore cup. I sure miss my 13% slip at cruise that I had before it was labbed. My plan is to test my props at WOT this Saturday.
