Go Back  Offshoreonly.com > Owners Forum > Hustler
Sea Strainers >
Sea Strainers
Sea Strainers
Old 08-29-2010 | 06:49 PM
Default Sea Strainers
I have a 2003 388 Slingshot with 575's
The tops on the sea strainers are cracked.
There are no model numbers or manufacturer name on them.
They have a black plastic knobs on top.
Anybody have any suggestions on what they are?
Thanks,
Chris
chrismconnelly is offline
Old 08-30-2010 | 10:43 AM
Strip Poker 388's Avatar
Rob
2001 mine came with Gill's
Strip Poker 388 is offline
Old 08-31-2010 | 06:00 AM
Strip,
The port side strainer top looks just like mine.
Is the other strainer top different?
Thanks for your help.
Chris
Old 08-31-2010 | 11:54 AM
Rob
Originally Posted by chrismconnelly
Strip,
Chris
the 2 that are the same are factory installed Gil. the other I installed for the innercooler. It is a hardin marine.They are bad about cracking.Not sure if design,pressure or someone stepping on the black knob, there pretty thick and shouldn't crack. I believe just the lid was 160.00
Old 08-31-2010 | 11:58 AM
Rob
Harding said they make a cover that helps it from cracking, its expensive.
Attached Thumbnails Sea Strainers-rez%2520engine%2520022%2520-medium-.jpg   Sea Strainers-620-913202.jpg   Sea Strainers-11-07-2-078-medium-.jpg
Old 08-31-2010 | 12:37 PM
By the way, your boat sounds great.
How is it in rough water?
I have heard over 90 the 388 gets loose, especially with the
imco lowers.
Mine is on the DL. A few undisclosed problems from the broker I
bought it from.
Should be in the water this weekend.
Chris
Old 08-31-2010 | 02:28 PM
Rob
imco lowers.
bought it from.
Chris
Thanks,it does ok in the ruff,but its not Cig either.Alot of people run a little tab above 90ish.loose is fast
Havent heard of the Imco lower hurting it.If I had to buy over I would buy them.
hey post some picks when ya get a chance
Rob
Attached Thumbnails Sea Strainers-hustler%2520105_1%2520mph%2520030%2520-large-.jpg
Old 08-31-2010 | 07:31 PM
This afternoon I ordered two from them.
$275.00 each
I guess I will add it to the bigger pile of money I am burning on this boat.
Performance boating ....gotta love it!!
I should have it in the water this weekend and I will take some pics.
Thanks again,
Chris
