Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
3M Fine Line Tape Usage Suggestions >
Old 08-30-2010 | 12:55 PM
Default 3M Fine Line Tape Usage Suggestions
I have a wooden boat Im painting and varnishing. Ill be using the 3M Fine Line tape and was wondering if youre going to do a few coats of paint (Interlux Brightside), can you just tape once, paint your 3 or 4 coats and then pull the tape once finished, or would you need to pull and re-tape with every coat? This is probably a silly question for most, but Ive never painted with this type of paint before and dont want a jagged edge when I pull the tape when Im done. Thank you for your help.
ak6143 is offline
Old 08-30-2010 | 01:58 PM
Steve 1's Avatar
You can put down a couple strips of it one on top of another,like we do for gelcoat graphics.
Steve 1 is offline
Old 08-30-2010 | 03:01 PM
So are you saying to perhaps put 3 layers of tape on top of one another, spray a coat and peel the top layer off and then repeat? Sorry if this is elementary, but Ive never messed with Gel coats either.
ak6143 is offline
Old 08-30-2010 | 03:15 PM
Steve 1's Avatar
Yes, you see with gelcoat we have to free the tape edge before the material gels or you pull up the gelcoat film with the tape,usually I will tape off with say 1/2" or better then come back with a 1/4" on top along the work edge,this is flagged so I can pull it with gloves on, down here it is a race with the ambient temp and the material kicking off right behind me.
Steve 1 is offline
Old 08-30-2010 | 03:18 PM
makes perfect sense. Thanks!
ak6143 is offline
