Carb guys..
Old 09-01-2010 | 09:09 PM
Default Carb guys..
Im running a stroked 496 dart alm 310cc heads elderbrock air gap intake full roller motor.Motor dynod wet with acceseries @500 hp 600 trq.peak hp was at 3800.Motor runs and pulls great to about 4800 4900 then thats it. First question Im running a Barry Grant sea demon 750 is this enough carb? Would a carb spacer change my peak hp, trq rpm to a higher rpm. Would I gain any hp overall.If so what combo, Ive read on here people using 2 in spacers one with 4 holes then a open hole.With the hole type should they be the same size as the carb mine are 1.4 dia.
redcorvetteman3 is offline
Old 09-01-2010 | 09:32 PM
Did you dyno with that carb ? Seems a little small to me . Or try one size smaller prop.
Jeff P31 is offline
Old 09-01-2010 | 09:41 PM
Rookie's Avatar
Peak HP @ 3800?? this is a typo, right?
You need a bigger carb.
Rookie is offline
Old 09-01-2010 | 09:47 PM
What boat is it in? What prop are you running? 3800 rpm hp peak on the dyno sounds kind of low. If you say it pulls great to 4900 than it sounds like it's doing pretty good. I would think that combo would be better with a 850.
picklenjim is offline
Old 09-01-2010 | 09:50 PM
yes dynod with that carb tried 23 mirage rpm about 5k 25 mirage 48 49. Also stock merc manifolds,I know these may be holding it back. Boat pulls strong with either prop pulls from 3800 to 4800 in 2 seconds then kinda just sits there. I dont need anymore hole shot (TRS drives)just top end. Boat cruises around 45 great, tops about 64Thought if I could easly change the sweet spot higher Id cruise arnd 50 55 top arnd 70 75 Respectable for a old 40 footer
Old 09-01-2010 | 09:57 PM
No not a typo motor has lots of trq low. I know the cam needs to be set different but thought carb spacers might help till winter.
Old 09-01-2010 | 10:18 PM
More speed equals more prop which takes more power. Not to be smart but it takes a lot of HP to make that much fiberglass go 75 mph. And I think you will find that the peak torque was at 3800 not peak hp.
Jeff P31 is offline
Old 09-01-2010 | 11:12 PM
Default 75 mph
my friend had a 1986 Fountain ICBM 12m with twin 454 single carb blown engines and the lower ends with no paint and no prop hub exhaust . probably 550 each maybe 625hp and that did 82mph
Chrisrug is offline
Old 09-01-2010 | 11:18 PM
Rookie's Avatar
No disrespect, but you are not going to see those speeds in that boat with that power.
Rookie is offline
Old 09-02-2010 | 08:30 AM
Default Carbs
None taken ... What I still realy want to know is about carb spacer will it move my power band or increase my rpm? Im positive if I could get 300 400 more rpm or move the peak hp it will run faster 64 65 gps now 5 more isint impossable
