38 Eliminator Eagle twin 572's at 750hp what pitch Prop? >
Old 09-02-2010 | 07:50 PM
Default 38 Eliminator Eagle twin 572's at 750hp what pitch Prop?
38 Eliminator Eagle twin 572's at 750hp what pitch Prop? it had stock 454's 330hp before with 22's?
socaldirtmod is offline
Old 09-03-2010 | 10:13 AM
what gear ratio are your drives?what rpm are you wanting to turn?
WR-1 is offline
Old 09-03-2010 | 10:42 AM
I would guess if you were running 22's with 454/330hp the gear ratio is 1.5. A good place to start would be 34 or 36's. Did you upgrade the drives ? I would think that your going to have trouble keeping B1's or XR's alive with 750hp.
JMS322 is offline
Old 09-06-2010 | 09:23 PM
I think you might need to change your drive gear ratio if you have 1.50's. I would try some 36 Bravo 1's to start.
Griff is offline
Old 09-13-2010 | 05:23 PM
Thanks for the replies guys, i forgot to check back for updates! ok i found my dyno sheet and attached a pic... i guess im a little bit of a story teller 725HP not 750!!
i didnt run it what i consider very hard... but it did hit the limiter at 6250 when i leaned on it. i dont have a speedo so i dont know how fast i was going? they are std brovo 1's with 1.5 ratio. i did notice that the little gearbox? that turns the fresh water pump and activates the fuel pumps was puking oil out when run at that RPM?
Old 09-13-2010 | 07:19 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Prop at 5800.
Let me know if you want some test propellers.
Brett
[email protected]
bbladesprops is offline
Old 09-13-2010 | 07:36 PM
What pitch would you suggest for that rpm? i would like to run a little less rpm if possible?
Old 09-13-2010 | 07:55 PM
Smile
Don't know.
The boat needs to tell you.
You need to go up in pitch to find a sweeter spot or, call me with a exact wet weight and I'll tell you the exact pitch you need to run 5600. But, I need the 6250 R speed as well in GPS form.
Brett
[email protected]
