Upholstery cleaner >
Upholstery cleaner
Upholstery cleaner
Old 09-05-2010 | 03:48 PM
Default Upholstery cleaner
Thought I read on one of these sites about using Westleys Bleche-Wite for cleaning tough spots on upholstery. Any input ? Thanks.
tinman565 is offline
Old 09-05-2010 | 05:41 PM
Too Stroked's Avatar
Although it might work - on white uphostery - I'd be very careful of that stuf for several reasons. First, it's got some bleach in it. If you happen to drip it on anything else (like carpet) nearby, you'll have whitre spots.
The other reason to be careful with any "aggressive" cleaner is that although it may get something clean, it generally does longer term damage to the upholstery by drying it out. If you do ue something like this, my recommendation would be to follow it up with an application of a good protectant like 303 Aerospace Protectant. This is especially true around stitching.
Too Stroked is offline
Old 09-05-2010 | 05:54 PM
we had a big problem at work. had a motor break a oil cooler hose and it sprayed oil over the ithe interior. we used purple power get it from autozone alot cheaper then castrol superclean and works and i think it better then super clean, but like in prior post u better use a protectent to keep it soft and from drying out. but make sure you hose it down to completely get rid of it after using on interior .
fkboatman is offline
Old 09-05-2010 | 07:54 PM
I had good luck with a lean mix of superclean and some oxygen bleach(oxyclean or similar) doesnt ruin colors or carpet, and scrub with a good vinyl brush that makes the most difference
hotjava66 is offline
Old 09-05-2010 | 09:57 PM
Bleche-Wite will work just fine on upolstery. It contains no bleach of any kind. I worked in the plant which manufactured Bleche-Wite for years and am very familiar with the formulation....
goldeneyee is offline
Old 09-06-2010 | 07:15 AM
I have used it for years!!!!!!!!!!!!!
checkeredpast is offline
Old 09-06-2010 | 08:34 AM
Bio-Kleen products work. The owner is a chemist and knows what works on particular materials. Using the wrong cleaner will damage your marine interior beyond repair. Give them a call. Worth your time.
http://www.biokleen.com/boat-cleaning
ROTAX454 is offline
Old 09-06-2010 | 08:36 AM
Expensive Date's Avatar
Roll- Off works great
Expensive Date is offline
Old 09-06-2010 | 05:52 PM
Besides having a great cleaning products, he is an avid performance boater too. Support the people/companies that support you. Taken at the 2010 LOTO shoot-out.
ROTAX454 is offline
