Power steering pump ? >
Old 09-08-2010 | 10:58 AM
Default Power steering pump ?
Is there a way to tell if my power steering pump is going or gone?
I took off the belt and I can spin the pulley freely, Don't feel anythng but I hear wining when the motor is runing above 3000. and steering IS slugish.
Thx
P
PARADOX is offline
Old 09-08-2010 | 08:46 PM
How is the fluid level,if it is low lines could be full of air
firehawkcat is offline
Old 09-08-2010 | 09:08 PM
Fluid is good. There is surely a noise from the pumps. Hard to tell which side.
PARADOX is offline
Old 09-09-2010 | 06:54 AM
Airpacker's Avatar
Hi Peter. Yes, those pumps will whine when the vanes in them wear down. The uneven wear spots actually "bypass" some of the fluid under pressure backwards towards the low pressure side and cause the noise.
Airpacker is offline
Old 09-09-2010 | 11:55 AM
I think I have some water in the system. I have to figure out how to drain it, then check the pumps. The trans fluid is milky.
I had a leak in the oil cooler, replaced it, but I guess i didn't get all the old fluid out.
PARADOX is offline
Old 09-10-2010 | 06:06 AM
just remove the return line and start it up for just a few seconds until dry...might have to flush out a time or two...
ezstriper is offline
Old 09-10-2010 | 04:58 PM
Default dont buy marine
Had the same problem with my convicer... merc pump was over $400.00 could not find it much cheaper. Bought a pump from Pep Boys for $22.00 and switched the cans. Ops check good for the past 3 years!
TWO YOOTS is offline
Old 09-24-2010 | 12:14 AM
Cig35Mistress's Avatar
PARADOX, your PM box is full so I'm replying here . . .
I've got a couple of pumps on the shelf that came of 454/400 Cyclones - don't know if they are the same, minus the blue paint? Shoot me an email to [email protected] anytime.
Thanks,
Harry
Cig35Mistress is offline
Old 09-26-2010 | 04:17 AM
Thanks,
Harry
Hey. Cig.
Didn't see this post., sorry. I posted on the other thread.
The part I need is 849906A28 don't need the pulley.
I took off the old pump, can't see or hear anything wrong.
Not in the mood to spend almost $500 for new, untill I know my problem is infact the pump.
PARADOX is offline
Old 09-26-2010 | 03:25 PM
What's your email Paradox? I'll send you some pics of what I have on the shelf. Not looking to get rich, just get cleaned out!
Harry
[email protected]
