Question about 500EFI Temps. >
Old 09-08-2010 | 04:06 PM
rrentsch's Avatar
Registered User
Default Question about 500EFI Temps.
In the spring this year I changed one of my thermostats to 160 degree. (at the time dealer only had one) That engine will run up to about 180 or 190 then the thermostat will open and the temp will drop to about 150 and then build again. It has worked like this all summer. My question is the other engine has a 140 degree thermostat and the engine stays around 150 or 160. I changed to 160 because I read that the engines run better if they run a little hotter. What about drilling holes in the 160 ? or should i go back to 140 ? Also changed both impellers at that time, the old impellers looked good and I have never had an issue prior to changing the thermostats. Any thoughts or experiences ?
rrentsch is offline
Old 09-09-2010 | 07:32 PM
Change back to 140*
Griff is offline
Old 09-09-2010 | 08:16 PM
You need the 140 as Griff states...The raw water going through the block with the 160 has a better chance of building a steam pocket.
Back4More is offline
