34' Wellcraft Fittipaldi SCARAB
It was/is a limited production boat based on the standard 34with the blinged out Emerson Fittipaldi design trim package. The 34 is essentially a 31 with a molded in swim platform if I recall correctly. It should weigh somewhere in the 7800 pound range and run roughly 69-70 mph with the 502s. They are a capable rough water boat with good handling manners.
It is a true 34 and the swim platform is bolted on. It is almost 36 ft long. I have the standard 1992 34 SCARAB and stock with 502's it would do 65 on GPS. And I think the advertized weight is arround 8500 lbs.
A friend of mine has a 1991 34' scarab fittipaldi, It is a true 34 with a swim platform that will measure 36'. Rides great, handles good, with 500hp 502,s it runs low 70,s.
RARE boats, you dont see very many of the 34' fittipaldis
Is your friends 91 the same as the 93 pictured that is being inquired about? For some reason I recall the 91s having a little spoiler looking thing molded in behind the sunpad and I thought they had side vents almost like a naca duct?
