exterior ply wood
Has anyone used 3/4 exterior grade pine plywood for stringers . I laminated three strips together and plan on using it instead of the pine 1x10 board that is installed now. Marine grade plywood would be the best but would the exterior grade be useable for stringers. Jp
From my understanding marine plywood and exterior use the same glue,marine plywood has less voids (knot holes ) and I believe marine has one or two more plies.I think if I had it I would use it because you are wrapping it completely with glass.Just make sure any holes you put in it are sealed so water can't get in and rot it. Just my 2cents. JOHN SR
Marine ply is certainly best but a quality outdoor rated ply is perfectly acceptable to save a few bucks, that's what I used in my scarab and I have access to just about everything. I have seen manufactuers use far worse. Stay away from dimensoinal lumber. The biggest thing is prep and a quality ballanced layup.
08 OPA High Points Champion
No never use pressure treated with fiberglass.
