1989 33' fountain executioner twin 540s and speedmasters >
Old 09-12-2010 | 01:49 PM
Default 1989 33' fountain executioner twin 540s and speedmasters
i was wondering what these boats are like if they handle rough water well, any problems with the hull. how fast it will run with 2 540s and speedmasters. it has hydraulic steering. looking at buying this boat.
Kichler is offline
Old 09-12-2010 | 02:02 PM
depends on what you are comparing it to..I personally think fountains ride rough as hell in rough water. but thats just my opinion..thay are a fast boat. and fairly well made..the 33-35's like a high x demension..700hp + wll run around 100
Baja555 is offline
Old 09-12-2010 | 04:49 PM
RICHARD CUNY's Avatar
My 32 with the drives in a bit runs right through 3 footers you just loose about 3MPH, when I am up on the pad maxed out the same 3 footers can get a bit loose, but I am new to this boat this season.
Rich
WATCHUS
RICHARD CUNY is offline
Old 09-12-2010 | 10:03 PM
was there any problems with the early fountain hulls?
Kichler is offline
Old 09-12-2010 | 10:17 PM
Like ANY old ride get a full survey WITH HULL SOUNDINGS!!
pullmytrigger is offline
Old 09-13-2010 | 08:41 AM
you said 89 right? I cant imagine a non stepped fountain running 100 it would take a lot more power than that. THe boat might run 80? Those were pretty heavy boats and with that bottom should be good in 2 to 4 footers. Not knocking the boat at all it has great lines but pretty sure it wont see 100mph
GTOFFSHORE is offline
Old 09-13-2010 | 11:31 AM
Brad Zastrow's Avatar
I owned a red 33 with 540s and Number 3's. It ran about 90 mph. Nice boat.
Brad Zastrow is offline
