Donzi Classic 18 Prop >
Old 09-12-2010 | 05:15 PM
Default Donzi Classic 18 Prop
Need some prop guidance. Here's where I'm at.....
Engine:
383 small block chebby
7 psi boost, roots
alpha drive, 1.63 ratio
Performance:
Mirage+ 25P 72 mph 5670 rpm
Mirage+ 27P labbed, 75 mph 5638 rpm
Mirage+ 27P labbed, 76 mph 5728 rpm
The speeds are GPS. The WOT rpm is an average of about 30 seconds at WOT from a datalog. Add 70 rpm for max rpm. The state of tune was the same for the 25P and first 27P run. The second 27P run was after tuning and raising the rev limiter 100 rpm. Basically it looks like all my runs are against the rev limiter.
I'd like to get my speed up and the rpm down (~500 rpm). Some time ago I ran a labbed 29P M+ with a slight drop in speed and rpm. The boat felt a little floaty and sluggish in the midrange. The 27 feels like a good all around prop and I'll proably go there when I stop chasing speed but that's not the goal right now.
Any suggestions? Going back to the 29 now that I have more horsepower seems like a logical next step but was wondering if anyone had a better idea.
Traveler is offline
Old 09-12-2010 | 06:52 PM
i wuold go to a 136drive or 150 so you will trun less rpm. i run 136 on my boat i pick up midrange 10mph 3600 i run 57mphif i run 150 i have to run4200to do 57
bajabob is offline
Old 09-13-2010 | 07:41 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
29 M+ props are act like 31 pitch M+'s.
I like the gear ratio change or I go to a small diameter Bravo 1 28-30 prop Labbed small to get the best over all performance.
Brett
[email protected]
bbladesprops is offline
Old 09-16-2010 | 07:31 PM
Probably too late in the year to do a gear change. Probably try the 29 and call it a year. How does my slip sound at 15%
Traveler is offline
Old 09-17-2010 | 04:56 PM
tmdog's Avatar
I have a 18 Donzi. Your slip is terrible. You definitely have to change the gear ratio to a 1:50.
For props , I would consder a Hydro OT 4 blade. You'll be cookin.
tmdog is offline
Old 09-19-2010 | 04:39 PM
So what is a reasonable slip number? My slip numbers have been consistent with different setups over several years. Perhaps I should make sure my tabs or something else isn't adding to my slip? If I can reduce the slip through "tuning" I shouldn't have to do any gear or prop changing right?
Yesterday I ran the 29 and it was a little floaty as I recalled but not awful. It is nice crusing at 55 or 60 without spinning up the motor.
Date Pitch Labbed RPM Actual Speed Slip
8/21/2010 25 N 5670 72 12.7%
8/22/2010 27 Y 5638 75 15.4%
9/6/2010 27 Y 5728 76 15.6%
9/18/2010 29 Y 5732 78 19.4%
Traveler is offline
Old 09-30-2010 | 09:21 PM
ZXXX Donzi's Avatar
I run a 383 Mag with a standard Bravo lower. Mine HATED a labbed and cutdown Bravo prop. I mean HATED it. Well ok, you could drive it but it did not hold a candle to a M+ or Turbo. More torque lean and chine walk with the Bravo.
I can easily run less than 10% slip with either M+ or a Turbo. I can run 71 (7% or so slip) on a good day and 69 any day. The Turbo (spare the bass boat talk) is the best all around. The M+ is not bad. These older model hulls with the deep X like 3 blades. My experience mirrors most of the new 18's with the 6.2 (377).
All changes if you run a shorty though.
I would do down in gear and try some more props. You should be able to break 80 easy with the right setup.
ZXXX Donzi is offline
Old 10-01-2010 | 10:15 AM
Smile
Remember, all Labbing isn't alike!!!! Lab recipes need to vary with each application depending on what the boat is doing.
Brett
[email protected]
Old 10-01-2010 | 02:37 PM
ZXXX Donzi's Avatar
Brett
Agreed.
I wanted to share what many of us know works on the same hull.
He should try a number of combos. Who knows, the added torque of a roots blower may not like a 3 blade down low. I am very happy with my setup but will still try more. Dialing it in is part of the fun. It is also a great way to learn your hull. At least as long as you can still have fun. I have yet to regret trying a prop and still have a lot to learn.
That slip is still WAY high though.
Old 10-03-2010 | 06:00 PM
i have a 24baja 718hp 136drive 23mirage prop at 5600doing 80.6 mph gps my boat runs best with 3blade. i think the 163gears are slowing you down . i think you will get more speed if you chage your gears
bajabob is offline
