after parting ways......
Old 05-08-2002 | 09:40 AM
jawbreakerkid's Avatar
Wink after parting ways......
....i have learned a little bit about relationships and the opposite sex in general. above all, i have learned "Why boats are better than women..." (you may have heard these)
1) Both are expensive and high maintenance, but you get to ride your boat more often.
2) You can steer a boat.
3) If your boat isn't running, you can choke it a few times and it'll crank up and run right.
4) You can swap your old boat out for a new one and still keep your house and car. Plus, older boats don't trash you every time they see you with your new boat.
5) You don't mind if your buddies see you being dragged behind your boat.
6) When you get on them, boats don't gripe about how you've gained weight.
7) Boats don't mind when you ride other boats.
8) A boat's bottom is always the same size as the first time you boarded it.
9) When boats retain water you can pull the plug and drain them.
10) When you have no use for a boat, you can put it in storage until you're ready to play with it again
jawbreakerkid is offline
Old 05-08-2002 | 09:43 AM
Playn's Avatar
Playn is offline
Old 05-08-2002 | 09:49 AM
Risk Taker's Avatar
Thumbs up
#'s 8 thru 10...LMAO
Risk Taker is offline
Old 05-08-2002 | 10:04 AM
Offshore Addiction
Cool
Old 05-08-2002 | 10:16 AM
Sydwayz's Avatar
Forum Regulator
ABSOLUTELY!!!
Sydwayz is offline
Old 05-08-2002 | 10:17 AM
GRH
Gotta luv those boats!
Old 05-08-2002 | 10:25 AM
CigDaze's Avatar
CigDaze is offline
Old 05-08-2002 | 10:48 AM
Milord's Avatar
Milord is offline
Old 05-08-2002 | 10:52 AM
Uncle Toys
You forgot the one, boats don't mind being in the wet spot.
Old 05-08-2002 | 11:05 AM
SeaDated's Avatar
How true that is!
SeaDated is offline
