Trailer electrical issue
Old 09-19-2010 | 08:19 AM
Default Trailer electrical issue
Converted my trailer to straight electric brakes. I have a junction box mounted near the tongue, with the 7 pin harness going into it. Then i have all the wiring from trailer lights/brakes going to it. Everything is hooked up and wired to its corresponding terminals.
First off, the electric brakes are weak. They are all brand new, and adjusted properly. When i turn park lamps on, the trailer running lights do not go on. If i use turn signals, hazards, or brake lights, the brake lights work, but all the marker lights blink too. Step on the brake, and the entire lighting system lights up on the trailer.
Any ideas? Before the electric brake install, trailer lights worked fine. The entire trailer is LED lights, so i am wondering if its some weird grounding issue, with the brakes and how LED's are polarity sensitive? Alll the trailer wiring is new, and in good shape. I have the junction box ground terminal grounded to trailer frame. All the lights, breakaway box, and brake grounds are on the same ground terminal.
MILD THUNDER is offline
Old 09-19-2010 | 08:22 AM
Ted G's Avatar
Enhance the ground between the truck and the trailer and see if that helps, use a jumper cable and go from the frame of the truck to the trailer ground and see if that works.
www.cbpba.com
Ted G is offline
Old 09-19-2010 | 08:34 AM
Also, forgot to mention. When i was backing the boat down the ramp, all of a sudden the brakes began working better, like something made a connection. Drove the empty trailer back to the storage place, and the brakes on front axle were working, and would lock up (front axle only) if i turned the gain up on the controller. Lights still the same though. Also tried a different truck to make sure it wasnt a issue with mine, and still the same, so i know its on the trailer side.
I will try running a jumper to the truck from trailer ground. I wired the brakes to where they ground to the junction box, instead of the frame near each brake assembly. I wonder if thats causing some sort of issue since the wire that connects the ground terminal of the box to the frame of the trailer is small, like a 14 gauge. Then again, cant see why that would keep the marker lights from illuminating, since they dont draw much current.
Old 09-19-2010 | 07:07 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I bought a pigtail from Champion Trailer Parts, and the wires/colors were not in the right configuration. I had to ohm out each wire from the 7 wire round to the open end of the pigtail, and make my connections to my EoH setup ignoring the colors.
Sydwayz is offline
Old 09-19-2010 | 07:16 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Don't get confused when looking at the schematic of the plug wiring......looking into the plug vs looking into the recepticle view. Mirror image
US1 Fountain is offline
Found light problem. Took the trailer side plug apart (plug that plugs into truck) and found the marker light brown wire off its terminal and touching one of the turn signal terminals. Lights working good now. As for the brakes, they seem to be working fine now, so leaving it alone!!
Old 10-06-2010 | 11:04 AM
Update. Lights all working fine. Brakes, not so much. Empty trailer, gain turned up all the way, will lock front axle tires. Loaded trailer, gain turned up all the way, barely feel engagement. They are engaging, but no where near what trailer brakes should be. All 4 magnets hum when brake depressed. Back trailer into water, as soon as they get submerged...wham! They grab like crazy.
Old 10-06-2010 | 11:10 AM
Check for proper brake shoe adjustment.
smcser is offline
Old 10-06-2010 | 11:39 AM
keep an eye on the ground Thunder , we pulled a good ground right off the truck instead of depending on the hitch & pintle
Old 10-06-2010 | 11:57 AM
+1 always ground trailer to truck ground. dont use the ball or pintle. you never know if you are getting a good clean connection. esp for people who use grease on them. doubt i could get a good ground through my ball due to all the grease.
Fixxxer22 is offline
