Converter Box
Old 09-21-2010 | 04:56 AM
Default Converter Box
hi fellas,
If I have two new pro XS's and opt for a livorsi dash do I need conversion or will it hook straight up.....
If so will it come with the package etc.
thankss
sonnycrockett is offline
Old 09-21-2010 | 09:16 AM
AppSysCons's Avatar
Originally Posted by sonnycrockett
hi fellas,
thankss
I assume you are refering to a Mercury Racing Optimax XS:
You can use the Mercury SmartCraft guages, they are plug and play, simple to install, but not the 'look' that many want.
Livorsi true analog guages, like my monster racing guages, require an AGI box to convert the digital signal to analog voltage signals.
AppSysCons is offline
Old 09-24-2010 | 07:35 AM
Thumbs up thanks
Where can that be obtained
Old 09-24-2010 | 08:42 AM
AppSysCons's Avatar
My AGI boxes came from Livorsi; however, since then Livorsi offers a new set of gauges called Vantage View.
"Vantage View® reads and displays performance data directly from CAN (Controller Area Network) for protocols: Smartcraft®, SAE J1939, NMEA2000® & Indmar. This line of gauges was created for those of you who need up to date technology but love the classic look of analog gauges."
I have had analog gauges in every boat for the last 25 years. My current Skater has Livorsi monster racing gauges, and a Mercury smartcraft SC5000 system view, race edition screen. My next build, will have 2 large format, system view type screens (one for each engine) directly in front of the pilot position, a trim indicator panel, and a large format navigation screen. Most likely no analog gauges, with the digital screens, they are redundant.
Old 09-24-2010 | 09:42 AM
I really depends on what gauges you want to read from the Optimax. On 250sx's I didnt use the converter box because the only analog gauge that I wanted to read was the RPM and there is a signal wire for that in the Key harness. On my boat I run these gauges:
RPM (PURPLE harness wire)
FUEL (Has own sender)
WATER PRESSURE (Mechaical Gauge)
Mini Smart Craft Gauge (Need Harness from engine to gauge)
Maritime_Eng is offline
Old 09-24-2010 | 09:43 AM
I will also be doing the same thing. No gauges on my next build.
