Anybody purchased anything from Dyno-Flo
good luck
Glad it worked out for you. My dealing was so so. Forgot to ship my timeing chain sets first. Then I told him what spings I was using he sent me lifted for a what would seem to be a useful on a lawn mower since they were rated 200 psi lower then what I need. I called asked hom about it he said "Ive been using those lifted on everything no prolems". My shop said hell no get the correct ones or take the motors as is. I called comp to verifie if they would work with my application. They said run those and buy motors since they will fail 1st run over 4K. I got all the pressure number off comp. Called Scott back told him what I had to go with due to the pressure of the springs he said " I dont know where you came up with those numbers but they are wrong". I said "Scott this is direct from comp, I went to the sorce id didnt want to build 4 engines only 2". He got all bent and said send them back Ill get you what ever the F you want. I was a little disappointed because I wanted to make sure all was good and I found an issue and called him on it and he was bent. I wasnt mad at all in the beggining I just wanted the correct ones and pay the differance and be on my way. It took 3 months to get them story after story why they couldnt get them. I called 3 diff. engine builders all with these lifted in stock. But since I couldnt get a refund just credit i was stuck. Sorry for the ramble good luck with the build
-Mike
-Mike
