5-Bladed Prop? >
5-Bladed Prop?
5-Bladed Prop?
Old 10-04-2010 | 02:48 PM
Default 5-Bladed Prop?
I'm looking at a Formula 252LS that might be too good to pass up. However, I've spent more time recently waterskiing and wakeboarding than fast running, and this boat has a 7.4L Mag with a bravo 1. I remember the nice cruising but lousy holeshot of my old Baja 252 with the same powertrain. I would have preferred a bravo 3 but it is what it is. Would a 5-bladed prop get me a substancially better holeshot and get me up on plane faster?
mausc is offline
Old 10-04-2010 | 02:53 PM
YES, BIG TIME! You will loose some top end. Make sure you go down on Pitch. Going from 4 to 5 blades, you will loose about 400rpm at the same pitch. Go down 2 Pitch from your 4 blade.
UrbanDisturbance is offline
Old 10-04-2010 | 04:53 PM
Vinny P's Avatar
I hate the winter!!
Just remember the more blades you run, the more strian on your drive.
Vinny P is offline
Old 10-04-2010 | 07:37 PM
Yeah. I know. But I have to think that a single 5-blader on a Bravo I is gonna strain less and absorb less HP than the counter rotating Bravo III.
I'll know tomorrow if my offer is accepted. If not this is all moot.
mausc is offline
Old 10-05-2010 | 05:44 AM
I have a 5 blade for sale, its a 24 pitch test time only. I still even have the box it came in. Let me know if you are interested.
HighPriority is offline
Old 10-05-2010 | 09:46 AM
I have a 23 5 blade Ill let go. I have about 5Hr on it.
goebel1 is offline
Old 10-11-2010 | 04:44 PM
OK. I bought the boat. Picked it up this weekend and just got done spending some time getting accustomed.
On REALLY smooth water with just under a half tank of gas and two people she'll run 52 MPH (on the gauge) at 4800 RPM, fully trimmed up (and it took forever to get there). That's with a 25P Mirage 3-bladed prop. According to the factory literature the factory prop was a 21P Mirage but someone decided to change it out. I'm thinking I should find me a 21P and see where I am before trading around for a 5-blade.
I'm guessing a 23 or 24 5-blade is still too much.
mausc is offline
Old 11-24-2010 | 02:10 PM
Thats 32% slip!! Something is wrong with your numbers. Either your tach or your speed is inaccurate (I have a feeling its your tach). It takes alot of power to turn a 25 pitch prop at 4800 rpm...Ill bet your actual RPM's are closer to 4000. This also explains why the factory prop was a 21P (which would put you around 4800 rpm).
You may be all the way down to a 17 pitch prop if you want to go 5 blades.
Powerquest_Baby!! is offline
Old 11-24-2010 | 04:38 PM
+1 on what Powerquest Baby said.
Gear ratio?
If that is the 454mag 385 hp motor, that boat should be faster too. You need a gps, if you want a correct speed reading.
A.O. Razor is offline
Old 11-24-2010 | 06:42 PM
Rookie's Avatar
Can't he just buy a used BravoIII lower and put that on????
Rookie is offline
