Does anyone use a load ditributing hitch? >
Old 05-09-2002 | 08:40 PM
Payton's Avatar
Charter Member #927
Default Does anyone use a load ditributing hitch?
I'm considering a boat that should tow at about 8500-9000 lbs. I looked at the hitch on my Navigator and it has a 7000lbs/700lbs tongue rating. With a load distributing hitch that goes up to 8700/870 lbs. I'm thinking I should get the load distributing setup. any thoughts?
Payton is offline
Old 05-09-2002 | 09:20 PM
BajaSquirt's Avatar
I just bought one for the same reason (on a smaller scale). I have a friend who was towing a 26ft cobalt with an 'X'. He swears by the distributing hitch. Set it up properly!!! You can actually unload the rear wheels of your tow vehicle enough to spin the wheels excellerating or pulling up a ramp. Also an improperly set up dist hitch will interfere with your trailer brakes.
All in all a grat idea, done correctly.
BajaSquirt is offline
Old 05-09-2002 | 09:31 PM
toolman's Avatar
From: Pennington, NJ/Delaware river/Upper Chesapeake bay
I had a similar situation with my 2001 GMC Yukon towing a Formula 303.
I opted for a heavier hitch from Draw-Tite, handles 12,000 Lbs. without being a weight-distributing setup. I love the way it tows, and you can really feel the surge brakes come on (I think it stops better towing the boat than without). It depends on what hitch you can get for your Navigator.
toolman is offline
Old 05-09-2002 | 09:42 PM
Intolerant1
My trailer has a very long tongue (no comments). The weight distibuters Ive seen attatch to the "A" part of the trailer (the beams that go back and away from center beam toward the fenders. I dont see how it would attatch to mine unless the load bars were 3 or 4 feet long.
Old 05-09-2002 | 10:07 PM
Bill272's Avatar
Go to www.draw-tite.com. Look under Hitches/ Weight Distributing/ and then there's an option for a pole tongue adaptor. It's a "T" that mounts to a straight tongue and acts like the "A" part of the frame.
Bill272 is offline
Old 05-09-2002 | 10:15 PM
Intolerant1
Thanx. Crap, now I dont have an excuse.
Old 05-09-2002 | 10:21 PM
Bill272's Avatar
Sorry about that. I have the same situation, really could use the setup, but am still putting it off. "See, I'm not the only one" isn't really a good excuse, but it can work in a pinch..
Bill272 is offline
Old 05-09-2002 | 11:18 PM
Does the load distrib hitch reduce turning radius or reduce the truck and trailers ability to "flex" over the top edge of a steep ramp? Does it take longer to hook up the trailer?
pullmytrigger is offline
Old 02-20-2006 | 02:57 PM
miamioffshore's Avatar
Default Re: Does anyone use a load ditributing hitch?
What about the pole tongue adopter, does it allow for the hookup of sway controls in addition to the weight distributing draw bars?
miamioffshore is offline
Old 02-20-2006 | 04:09 PM
Sydwayz's Avatar
Forum Regulator
This is a VERY old thread. You cannot use traditional sway controls with a surge brake system. Check this thread for a lot more info. You will need to register to view the pictures.
http://www.offshoreonly.com/forums/s...vy+hitch+balls
Sydwayz is offline
BillR
2
10-24-2007 08:36 AM
FROGMAN524
13
06-15-2007 05:44 PM
BajaRunner
14
05-06-2006 07:13 AM
Nykamp
Cigarette
5
04-12-2005 10:03 PM
