Will an Alpha transom plate bolt to a King Cobra hole? >
Old 10-05-2010 | 08:11 PM
randymbtech's Avatar
Default Will an Alpha transom plate bolt to a King Cobra hole?
Hey guys, I am looking at a Four Winns Liberator, and it has a King Cobra transom plate and outdrive, but no motor. The only way I would consider this project, is if a Merc Alpha (Gen 1 or Gen 2) transom plate assembly will bolt up to the king Cobra hole in the transom.
Can anyone tell me if this will work without fiberglass work to the transom???
randymbtech is offline
Old 10-06-2010 | 06:25 PM
Audiofn's Avatar
Charter Member #232
There was a thread the other day that said that a bravo would bolt up. As far as I know the Alpha is the same bolt patter with two less holes? So you should be ok but don't take my word for it.
Put your best foot forward!
Audiofn is offline
Old 10-06-2010 | 06:53 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Yes, same bolt pattern..
John jr
Fenderjack is offline
Old 10-06-2010 | 06:59 PM
Thanks guys, I appreciate it,
Old 10-13-2010 | 07:32 AM
PatriYacht's Avatar
Isn't a King Cobra stronger than an Alpha?
PatriYacht is offline
Old 10-15-2010 | 09:24 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Yes it is stronger than an alpha, the regular cobra was too. But parts are getting to be a hassle as it has been discontinued for a while now.. J / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
