Drive Trim indicators?
Old 10-05-2010 | 11:16 PM
SlowPlay's Avatar
Default Drive Trim indicators?
Well as most of you know i just took the plunge and bought a 382. Well on the long list of things that need fixing drive trim is one of them.
Here is my problem.... the style that i have clamp onto one of the rams and has a piston that hits the end of the pin that holds the trim pistons and what not.
Well i guess when they had it all apart several years ago to do the motors they didnt put the drive back together the right way. one of the pins was installed the wrong direction so the trim piston doesnt hit anything (and looks to be a bit bent from deflection).
I already know i need to replace the cables on both sides since they are rusted and shot, should i stick with these and rebuild them or is there something else worth looking at? I really do not like the fact these are not working, nor is the working indicator very much help.
any thoughts? Ill try to get some pics but its sitting in the water until this weekend probably.
thanks guys
SlowPlay is offline
Old 10-06-2010 | 01:06 AM
They are a merc part and have a merc price to go with them. I still think they are the best ones out there though.
Here is the parts schematic and part numbers
http://www.mercruiserparts.com/Show_...28846063A+1%29
Griff is offline
Old 10-06-2010 | 06:41 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
We sell new actuators for $175.00
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 10-06-2010 | 08:05 AM
Underdog88's Avatar
Veteran: Navy
I have those and made my own indicator sticks. Very easy conversion. I needed the dash space taken by the big square panel.
Guess I can't post a pic here... I tried.
Underdog88 is offline
Old 10-06-2010 | 08:15 AM
No matter which actuator you get, Use the stainless Marine "No Slack" Indicator Cables. If your drive moves at all it will show up on the display. With a regular morse type cable your drive can move up to 1 1/2" before the slack comes out of the cable and moves the display. Don't Skimp..
fastdonzi is offline
Old 10-06-2010 | 08:45 AM
I have a similar problem. I have the Stainless Marine No slack setup. The cables are in real good shape, and the SB side works perfect. The hardware on the port drive is bent and has kinked the cable. I just need the connection hardware and a cable end (if they can be replaced) to make it good. Anyone sell just the end hardware?
CrownHawg is offline
