Bilge painting
Old 10-06-2010 | 09:55 PM
Default Bilge painting
Replacing stringers and transom. I was recomended to use epoxy resin. I would like to sand and finish the whole bilge and transom area. I have painted autos in the past but I have no idea what finishing materials are compatible with epoxy resin. Normally I would use a urethane Primer surfacer then top coat with a single or two stage urethane. Would gel goat be a better alternative for build, sanding and duribility?
tbanzer is offline
Old 10-07-2010 | 09:48 AM
Hey guy i have always used Imron or Awlgrip great stuff and very durable and in fact Skater uses 555-U Imron for the bilge area .
SUE C Q is offline
Old 10-07-2010 | 12:12 PM
glassdave's Avatar
Neno the mind boggler
you can use anything but poly or vinylester based products. Gel coat will not work over epoxy. I use PPG's single stage Concept and it works well.
08 OPA High Points Champion
glassdave is offline
Old 10-07-2010 | 01:12 PM
Default Fixx
Dave, wouldn't he be able to use duratec primer and block it flat then top coat it with imron or ppg's concept paint?
FIXX is offline
Old 10-07-2010 | 08:42 PM
Hey guy you can use Imron or Awlgrip on epoxy without a primer and Skater has been doing it for years .
SUE C Q is offline
Old 10-07-2010 | 10:12 PM
Is the ppg a top coat? I am going to need something to fill and sand prior to top coating.
tbanzer is offline
Old 10-08-2010 | 06:48 AM
CIG3's Avatar
I like Awlgrip for bilge painting. (Snow White)
CIG3 is offline
Old 10-08-2010 | 05:55 PM
What can I use as a filler or primer surfacer to level the fiberglass prior to top coating.
tbanzer is offline
Old 10-08-2010 | 08:02 PM
I repainted my bilge this year and a new producy from Interlux, called Perfection. It is a little less expensive than Awl Grip and you don't need a respirator. It turned out great, snow white and easy to come by...west marine.
It is hard a nails and very hard to scratch. I could not be happier.
MACTIME is offline
Old 10-09-2010 | 12:15 AM
+1
I have had my bilge done for 8-9 years now. Still looks almost perfect... It took a pint this year to make it perfect. Goes on with a brush and roller and looks like it was sprayed!
I know that other products work, but why mess around trying when there is a proven product that stands the test of time?
Todd Hartigh is offline
