What drive to use? >
What drive to use?
What drive to use?
Old 10-10-2010 | 06:23 AM
dlj
What drive to use?
I have recently bought a 2004 Daytona with 2 496 HO's and Bravo drives. The boat will run mid 90's with gas and 2 people and I have got 98mph almost empty of fuel and on a cool day, but compared to my other single engine boats (a Nordic and a 234 Edge Eliminator) the boat does not pull hard in midrange and is slow out of the hole. It has IMCO set back boxes, but appears to be stock other than that. I first thought I would just drop a couple of Whipple’s on this and be easy on the drives, but after some research, felt this was just a waste of money. I am now building two new 632 Dart motors and hope for 750hp each and am very confused from all these posts as to which way to go for drives. Everything from Konrads, IMCO, Arneson, Teague, BMax, be easy of stock, and just don't drive the boat much at all seem to be the consensus here. Does anybody have any advice for my boat/power combo that will produce a fairly rugged ride. I do not mind going through the drives once a year or even keeping a spare drive at the lake for emergencies, but I hate being towed in. Any solid advice. Also, any idea of price on the recommending drives. Between these two engines, the anticipated cost of the drives and rigging, I almost wish I had bought a 30’ with # 6 drives and big power out of the box, instead of my plan of beefing up a stock power 28’. Thanks for any help you can offer!
dlj is offline
Old 10-10-2010 | 03:29 PM
Imco SCX uppers and SC lowers should handle that HP. Or go with your plan B and buy a #6 boat
JRider is offline
Old 10-10-2010 | 10:04 PM
My Teague XR is rated for around 900hp im putting about 600hp through it no problems, if you hammer the throttle out of the hole i think you could tear up any drive. Then you will have some guys putting 1000hp on a bravo 1 and not having any problems.
firehawkcat is offline
Old 10-11-2010 | 05:25 AM
dlj
Default What Drive to Use
I had considered both the IMCO or the Teague drives, but I read many negative comments about both here in these forums. One long thread focused on the IMCO drive causing a loss of top end speed in the tune of 7-8 mph and the Teague drive not holding up. I don't mean to sound stupid, but unless I am WOT my boat just about won't plane. Do I need a complete new drive or can I beef up the upper or lower. Also, I read a lot about being easy on a drive. What exactly does everyone mean? Thanks
dlj is offline
Old 10-11-2010 | 09:59 AM
Default B-Max
Is the Bmax a good strong drive and is the company back in good shape?
ElimiNordic is offline
Old 10-11-2010 | 08:18 PM
DLJ,
You won't need full throttle to get on plane with your new motors.
Peak torque is what kills drives probably around 4K rpm's
Being easy on applying throttle coming on plane and during acceleration will be easier on the gears.
If you get air and the props break loose if you don't throttle back you have just toasted your bravo.
Increasing the amount of blades and increasing pitch will be harder on drives.
The Teague drive is better than an XR.
It seems initially the SCX with the SC lower looks to be a winner. The SCX lower is not usuable to most due to hydrodynamic issues.
The BMax looks better all the time now with the new owners.
Conrad is a good product but you must use a transmission which will require rerigging.
Arneson seems awesome will require a lot of rerigging.
Cost of all these is high. Consider overall value of the boat when considering this, you will not get this back on sale if you need to.
Teague, call and ask. IMCO SCX/sc 12K, Helmet 800, B-Max 15K,
Conrad more than these plus rigging, $$$, Arnesons, don't know accurately but 20K plus rigging would be close.
If I were you I would keep your boat as is for baseline testing. Put your new power in, up your pitch in whatever your using by 4 or 6 and be easy on it. BBlades has a demo prop program. See how handles and planes. Call Eliminator and ask what set up works on the 30. Then change to the drive of your choice most likely SCX or Bmax. With the data you have you will be able to better predict what size lower to use. You will need to spend about 30K plus to get to a higher level of reliablility that unfortunately may not be bulletproof............. The first time you feel the power you will think it is worth it. Eric
SkiDoc is offline
Old 10-11-2010 | 09:36 PM
DLJ what prop are you useing, wot out of the hole will just about bust any drive, more sooner than later. If you have a 3 blade that could be the problem
Old 10-11-2010 | 09:37 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Originally Posted by KYElimEagle
DLJ,
Eric, if you are advising him to spend $30K on something and not be reliable, you just blew the cost of the Arnesons and you are still behind on speed and handling.
Just something to think of.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 10-11-2010 | 09:48 PM
JasonSmith's Avatar
I want to meet just one guy who has 1000 going through a Bravo who doesn't have issues. The only way that is possible is a guy who just installed a 1000 hp engine in his boat & hasn't ran it yet.
From what I gather & I have yet to be quoted an actual Bravo to Arneson conversion price. Arneson would be my choice. The Imco SCX looked to be a great alternative at 1st, but it has it's issues that are becoming more & more every day as more make it to market.
JasonSmith is offline
Old 10-12-2010 | 12:08 AM
I can't speak about the condition of the company. Don't know. My B-max's at the end of my fourth season now with what looks like no wear and no problems. I run it behind a 720 hp 727 tq Pro Charged and injected 468. It is in a 96 Velocity 260. I run mid 80's about half loaded. Better light.
I would say I lost a bit of MPH not sure how much because I freshened and beefed it up a bit about the same time. I have thought of going with a shorty.
Rated to 14000lb 950 HP and TQ last I looked. About a $15,000 bolt on investment and worth every dime. I could break a Bravo by hitting the trim button.
You said you dont like to be towed in! That's why I run it.
RBeyer is offline
