water pressure >
water pressure
water pressure
Old 10-10-2010 | 03:59 PM
Default water pressure
i have a 96 502 magnum. i put a water pressure gauge on the sea water pump. i was wondering what it should read? thanks
perky2196 is offline
Old 10-10-2010 | 06:41 PM
U should take it of the intake manifold ( thermostat housing ) ..to get a good reading of the engine !!!!!
It should read not less then 15 WOT and not more the 28 WOT !!!!!!!!!
DareDevil is offline
Old 10-10-2010 | 07:33 PM
5psi at idle,,,,20-30 at speed,,,thats what mine read
TWIN-SPINS is offline
Old 10-11-2010 | 05:47 PM
Unhappy
i just put a hardin marine stainless sea water pump on with a new autometer gauge off the 1/8" fitting on the pump. i have 0 idle and about 5 or 6 pounds at 3000 rpm. any guesses? thanks. it is pumping water at an idle coming out of the pipes. it seems to actually have a slight vacuum at the gauge line when it's idling
Old 10-11-2010 | 06:20 PM
Brad Zastrow's Avatar
Not really sure about the gauge on the pump concept. I would be more concerned about water pressure in the block.
Brad Zastrow is offline
Old 10-11-2010 | 06:25 PM
Default Fixx
Get the line away from the sea pump and try plumbing it into the front of the intake..
FIXX is offline
Old 10-11-2010 | 07:11 PM
ok. i will try that tomorrow. odd , thats what they said the pump was tapped for was a pressure gauge thanks
Old 10-12-2010 | 01:02 AM
X2 Pressure in the block is what matters.
Are your numbers running the boat on the hose, running it in neutral at the dock or actually running the boat???? It makes a big difference.
Griff is offline
Old 10-12-2010 | 03:33 PM
i just had it running on the hose.
Old 10-13-2010 | 02:03 AM
Water pressure numbers on the hose are worthless other than at a fast idle. You need to run the boat at speed for real numbers. A hose can't supply enough water for accurate readings and does not duplicate the water being forced in by the speed of the drive/pickup going through the water.
Griff is offline
