Rubber gaskets for through hull exhaust >
Old 10-11-2010 | 02:06 PM
bigboat28's Avatar
Default Rubber gaskets for through hull exhaust
Where can you get those rubber gaskets that go around the exhaust pipes that go through the transom?
bigboat28 is offline
Old 10-11-2010 | 03:47 PM
88Fount33's Avatar
Beak botr
Default Grainger
i ordered standard 4" diameter 1/8" cross section o-rings from grainger and they fit fine. They fit the groove in the ring and had to be lubed up to slide onto the Big Pipe.
88Fount33 is offline
Old 10-12-2010 | 01:05 AM
http://www.cpperformance.com/c-462-angle-cut-tips.aspx
Griff is offline
Old 10-12-2010 | 09:25 AM
bigboat28's Avatar
