Help me prop my Thunder
Ok heres the deal
Boat is a 25' Active Thunder spinning a 26p Bravo I
PitchxRPM 26x5000
------------- = Theo Speed ------------ = 82.07
Gearx1056 1.5x1056
TheoxASpeed 82.07x74
------------------ = Slip ------------- = 9.16
Actual Speed 74
Actual speed is a guess but I think the prop slip sounds about right using that number......Yes or No
Here's the Dyno info;
Max Torque; 583@4600
Max HP; 520@5300
This is where I need to look for prop;
RPM Torque HP
4900 549 513
5000 545 519
5100 525 510
5200 523 518
5300 515 520
5400 499 513
Rev Limiter is set at 5300 or 5400 I need to double check.
What props should I be trying? What RPM should I be shooting for? Escape Velocity and BigWaves both have props that may work. One is a 26p lab finished and the other has added cup. There are several other 25' AT's that claim to be running considerably faster with less HP/Torque, where could I be losing.
Any help would be great.
PitchxRPM 26x5000
Gearx1056 1.5x1056
Actual Speed 74
Max HP; 520@5300
RPM Torque HP
4900 549 513
5000 545 519
5100 525 510
5200 523 518
5300 515 520
5400 499 513
Not sure if this helps, but the One Vision Thunder runs a 28 Labbed bravo. Funhome & I tested quite a few props and found the 26 Hydromotive to be VERY close, but handled a litle better. For some reason, the boat didn't like the stock 26 Bravo at all. Lost speed and rpm's. We then sent a box stock, (new) 28 Bravo 4 blade to a place in Wisconsin, (GAWD I wish I could remember the name of that place). They lab finished the prop much like Mercury did, but we asked to have some of the bow lift taken out. (The 25 already has a buttload of bow lift). This gave us .2 mph faster top speed and handled as good as the Hydromotive and improved accelleration.
final numbers were 81.7 @ 5200rpm w/ two people at approx 800' elevation, hot day running low on fuel.
Hope this helps.
Hope this helps.
Abby-someone
Abby-someone
you need to get a 24 bravo. dropping two sizes will give you that 400 rpm your looking for. hence more speed. if your motor is new give it 40 hrs . then try the 26 bravo and see what your max rpms are then.
Treadewll
Treadewll
Gordo,
It all helps, thank you. I bought my boat used from Pat so Im not sure how agressive it was intended to be. It was biult as a pleasure boat not F1. Although the X-Dimmension does not seem aggressive I dont have anything to compare it to. Could I lose that much speed in the X and additional wieght. Im assuming you are running an HP500 @ 470hp. Do you have a stand-off box or anything else?
Treadwell, do you think I should run it up 400rpm to be up on the rev limiter or is that how your looking at the power curve?
Motor has more than 60hrs on it.
Thank you for your input. Im learning a little more every day.
Tantrum,
I wish i still had my 25, I would lend you the hydromotive 26 that i ran on my thunder. I know the previous owner had his"racing prop" worked on. The best I saw was 78-79 mph, very light on fuel and alone. My boat did have a racing layup and extention boxes, but I would guess you are a few hundered (400 to 600?)pounds more in weight.
I never tried the bravo's but I heard the same thing that Gordo said, probably because he is the one who told me.
I would see if anyone has a 26 p hydromotive you could borrow.
I would also mesure your x dimension and see where it is in comparision to maybe Gordo's.
These two factors, weight and x dimesion could be where the speed is getting scrubbed.
Good Luck
Dan
Good Luck
Dan
Tantrum,
Not sure which boat you bought, but if it is the recreational version, then you do have a lower "X" cut in the transom which won't help speed any. It also means that your boat possibly weighs as much as 800-900 lbs more than mine which really doesn't help any. In fact, If all the above are true, then I'm pretty impressed with the speed you are now getting. On the other hand, I'll bet you plane off much better/faster than I do.
Getting a lab finished prop will gain you about 200rpm's, and gained us almost 2 mph ofer box stock stuff. I'm not sure what rpm's you are running at 74mph, but Eric may be closer to the right track for your application. Either way, I would start saving my Pepsi points and get a lab finished prop.
Abby-someone
Abby-someone
Oh, by the way, We did have a Stellings box on for a while, but it added weight to the back of the boat which didn't help balance at all, and it created so much more bow lift that the boat was really out of control. Made for some great video, but was definately a higher pucker factor. Besides, we got back almost all the speed without the box after more testing.
Racing tip for the day...
Running 81 mph for a few miles in control will beat running 82 mph for a few seconds out of control any day!
Abby-someone
Abby-someone
