Props Coated with Salt?? >
Old 10-12-2010 | 09:42 PM
Default Props Coated with Salt??
Recently bought a new set of Bravo props, have put only about 15 hours of run time with probably 30 hours of total time in salt water since install. Props and drive shower tubing has the same crust as in this pic. Any thoughts on what could be causing this?
Thanks,
Rick
Powerquest230 is offline
Old 10-13-2010 | 12:12 AM
Registered User
Try lime away or CRC. Then rinse good. Works great for the high calcium and alkiline water at Lake Havasu.
dave
boatcrzy is offline
Old 10-13-2010 | 02:12 AM
It's just mineral deposits. Spray it with some CLR, Lime Away, or Sno bowl toilet cleaner and rinse well.
Griff is offline
Old 11-05-2010 | 06:10 AM
yea...the salt water, rinse well with fresh water after every use
ezstriper is offline
Old 11-05-2010 | 06:18 AM
BONDO10's Avatar
Do you have any zincs on there?
BONDO10 is online now
Old 11-05-2010 | 08:11 AM
that isn't really 'salt' it is from 'hot' water. i.e., water with electrical current in it. Wherever you dock your boat is screwed up, which is pretty common on canals and older marinas.
VetteLT193 is offline
Old 11-05-2010 | 08:21 AM
CigDaze's Avatar
I see you're in Palm Harbor so we pretty much boat in the same waters. I don't have anything like that visible on my gear ever. I'm going with Vette's theory of stray current. It looks like electrolysis deposition.
CigDaze is offline
Old 11-05-2010 | 08:59 AM
Make sure you have an Anode on your drive.
UrbanDisturbance is offline
Old 11-05-2010 | 04:40 PM
BZ's Avatar
BZ
If the boat ever stays in "Home Port" I heard thery are bad for current in the water....
BZ is offline
Old 11-06-2010 | 01:55 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Stray currents usually burn propellers removing material. However, deposits can form pre burning. Deposits can appear from high mineral contents or from cavitation. If the problem turns into porosity, there may be a shore power issue. If the porosity only occurs on the prop, it is most likely cav. burn. There are units called galvonic isolators that redirect the current to ground and save props, lower units etc. if there is stray voltage at your dock.
Brett
[email protected]
bbladesprops is offline
