Max safe rpm for bravo one? >
Old 10-13-2010 | 05:23 PM
Default Max safe rpm for bravo one?
I am finishing up a forged 489 stroked 454 in my single engine baja and wanted to see if i could safely rev it to 5800 without hurting my bravo 1??
grjdc1 is offline
Old 10-13-2010 | 08:04 PM
Tinkerer's Avatar
I used to run mine at 6000 RPM till I changed to the current 28 pitch B1's
Tinkerer is offline
Old 10-13-2010 | 08:10 PM
I ran mine to 6500 RPM on saturday!
26awesome is offline
Old 10-13-2010 | 09:02 PM
Figured it wasnt a problem, but a few local guys said id blow the drive.
grjdc1 is offline
Old 10-13-2010 | 09:24 PM
Its only a matter of time.
waconda is offline
Old 10-13-2010 | 09:37 PM
fireboatpilot's Avatar
RIPSTA Racing Team
It's not the rpm's that will kill it but the torque pu to it. Go easy on the hole shots and acceleration bursts and it could last for awhile. Start hammering it and it's a goner for sure.
fireboatpilot is offline
Old 10-14-2010 | 01:32 AM
More rpms= more heat= more chance of failures
I would say 6000rpms max with lube changes every 20 hrs
Griff is offline
Old 10-14-2010 | 03:06 AM
hi fireboat pilot paul here from england are you still selling drives you never got back to me with price regards paul
paul buckner is offline
Old 10-14-2010 | 05:14 AM
I have one that I run at 5800 to 5900 rpm for short periods of time with a nitrous blast and it has been fine for years. I do have back up drives reading and waiting to go.
ElimiNordic is offline
Old 10-14-2010 | 05:53 AM
Mr Gadgets's Avatar
Charter Member #601
I used to run my 25' Checkmate to 6300 on a regular basis. But that was not a 5-10mile run. More for the river speed runs. Used to be the pinion gear would walk over the driven gear, but that was before people properly lashed the upper gear set. I used to build the B1 on the Caster's boat, National Champ, he would race it very hard.. see 7000rpm on the telltale.
You are better off running a higher rpm with less load and deal with the cooling than lug the motor down with a big prop and load the drive. just my .02.
Dick
Mr Gadgets is offline
