zerk fitting on axle + bearing buddy ? >
Old 10-17-2010 | 04:38 PM
Default zerk fitting on axle + bearing buddy ?
I just picked up a boat and the trailer axles have zerk fittings, can I or should I use bearing buddies with these?
ttuton is offline
Old 10-17-2010 | 04:49 PM
offshoredrillin's Avatar
no, the bearing buddy pushes grease in from the outside of the axle, if the zerk is in the end of the axle, you just grease it and the grease goes through and comes in through the back and forces the old grease out. take the metal caps off or the rubber plugs and inspect, feel free to put more in and make sure they are lubed. i just replaced 4 hubs and redid all 6.
offshoredrillin is offline
Old 10-17-2010 | 07:39 PM
Make sure the rubber caps are not dry rotted! They are cheap @$2-3 each.
smcser is offline
