Winterizing with a XR Drive >
Old 10-20-2010 | 05:22 PM
Default Winterizing with a XR Drive
When I ran the boat last time out of the water with the muffs there wasn't much water coming out of the exhaust. I noticed that most of the water was running out of four holes at the front of the nose cone. Should I try and block those off so the antifreeze goes into the motor and not on the ground.
haulinit is offline
Old 10-20-2010 | 07:40 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Gotta plug/tape those front holes too to use the side muffs
US1 Fountain is offline
Old 10-20-2010 | 07:53 PM
You might want to check your impeller.
kjm5125 is offline
Old 10-20-2010 | 08:00 PM
gotta cover those inlets either with tape or buy the kit from mercury; looks like a bottle cap that goes over the holes and snaps together around the drive. if that does resolve the water issue, check your impeller.
MC-BOYS is offline
Old 10-20-2010 | 08:16 PM
It was only for a short period of time just long enough to check the fuel pressure.
haulinit is offline
Old 10-20-2010 | 08:20 PM
Sorry reread the post, the impellers (dual stage) are in good shape. I have ran the boat several times since then and had good water pressure.
haulinit is offline
Old 10-20-2010 | 08:51 PM
c_deezy's Avatar
If possible, easiest thing is to put a bucket in the bilge, then pull the hose off the transom assembly and stick it in the bucket. You may need a little longer hose for it to work, but that's the way I do it and it works like a charm. I have some jobbie I rigged up with a 1-1/4 hose, then a ball valve, then an adapter to go to a garden hose. I usually pull the hose off the back of the pump and hook that up to flush, run on the hose, etc.
c_deezy is offline
Old 10-21-2010 | 10:29 AM
Too Stroked's Avatar
Of course all of this assumes that one can winterize a motor by simply running antifreeze through it. Personal opinion here, but I'm not a big fan of this method. There are simply too many chances of not getting the proper mixture of water & antifreeze in all of the different areas where the cooling water flows.
Now, if you drain everything first, then refill the system with antifreeze, I can live with that.
I will now stand by and get burned at the stake by everyone who's used this method. Remember, I work at a marina where we winerize over 400 boats each year. We're always looking for the fastest, safest, least expensive method. We experimented with using this method several times - and concluded that it was too risky for us.
Too Stroked is offline
Old 10-21-2010 | 01:03 PM
c_deezy's Avatar
That's one of those things you just assume the OP is doing prior to pumping anti-freeze in it. If you aren't doing that, then you should be.
That said, in the past I've just ran a/f in without draining, but usually ran about 12 gallons through before shutting it down...
c_deezy is offline
Old 10-21-2010 | 05:37 PM
The motor is procharged so it has a intercooler im assuming that if it shoots A/F out of the intercooler discharge port then the intercooler should be good?
haulinit is offline
