What's a good prop slip #
I don't know. Somewhere around 6 I think, I have more of a torque 5,000 rpm motor. But I'm changing to a smaller Blower pully on top.. Should get another 50 ish? hp.
The motor in my yellow boat makes about 718 @ 7700.. I was thinking of swaping it w the fountain.. But it's a 468 w less torque and need C12 fuel and to be primed bla bla bla.. Fun thought though
I was wondering what good slip numbers should be. My 32 has 1.5 Bravo's, 28 Q IV's and we got these numbers yesterday. It was in the 70's temp, with a nice wind chop, just what this thing likes, but I couldn't pull the r.p.m like I normally would. Last winter I had a prop guy go over them and it seems I have lost 200 to 300 r.p.m., it would have ran 5200 to 5400 r.p.m. last year.
When we looked at the props last year not all of the blades were the same size
They are now.
2500 - 34
3000 - 46
3500 - 55
4000 - 64
4500 - 72
5000 - 82
Original test sheet shows 27 hydro, 84m.p.h. at 5300 r.p.m.
They are now.
2500 - 34
3000 - 46
3500 - 55
4000 - 64
4500 - 72
5000 - 82
if you are 10% consider yourself doing great for a single engine boat. If you get much tighter on your slip it has been my experience that you will start breaking drives. However if you stilll want less slip you can go bigger in prop diameter or with more blades.
My 29 with twins is 6% but it is an older boat with deep drives. My 35 has 12% slip but has high drives and then i put 2shorties on top of that (21 3/8" therotical x deminsion). The 29 is probably a little tight and the 35 may be a little loose but it all comes down to speed and with both boats it is were it is to obtain my goals.
Allen
Allen
Thanks for your help. I have 2 props. I noticed w my bigger prop it just LOCKS when I get on plane . Not so much w the other prop.. I'll take it easy in my outdrive more w this prop as well..
