Drain plug -MkV 704 L - help >
Old 10-30-2010 | 11:03 AM
Default Drain plug -MkV 704 L - help
I have a 1993 7.4L that I am winterizing. I can't locate the port side plug to save my life. I've removed all the plugs I can find on that side, but they were all oil gallery plugs. Starboard was easy to find, a brass plug at the base of the block. Where the heck is the port drain?
apollard is offline
Old 10-30-2010 | 11:06 AM
PatriYacht's Avatar
Same area, keep looking.
PatriYacht is offline
Old 10-30-2010 | 11:22 AM
Same spot other side and stick a small screwdriver up in the hole while it's draining to remove any debre in the hole and make sure it is open when the water out so you no all the water is out then just pull all your water lines plus the water pump hose too and exhaust water hose's too and fill the engine with antifreeze
here is a sevice manual
www.boatfix.com/merc/Servmanl/16/16cov2_1.pdf
Rockfish71 is offline
