Seawater pump shaft shot out >
Old 10-30-2010 | 02:09 PM
Default Seawater pump shaft shot out
I was running around 4000 RPM out of a pass when I lost steering. Figured I threw a belt. Opened it up and the seawater pump pulley and shaft had shot out from the pump on my starboard motor. Merc 2 year covered a whole new pump + install (and covered a seized alternator, another one that was putting out half the volts and a breaker). Motors (496s) have 325 hours on them.
Anyone else had this happen?
jswfl09 is offline
Old 11-01-2010 | 10:45 AM
My seapump was moving axially enough that the belt jumped off (496ho). The bearings get worn out. I think mine happened around 350 hours.
twanger is offline
Old 12-05-2010 | 05:25 PM
Thanks. I forgot to get back to this. Very strange.
I got it replaced and now within 20 hours of that I noticed a leak on the port side pump around the shaft. Obviously not going to win with these pumps - I never had these kind of seawater pump problems on the previous 496 boat.
jswfl09 is offline
Old 12-06-2010 | 06:06 AM
Just happened to me on my 6.2. Seems to me that the front seal that is pressed into place is the only retainer for the whole setup. I know the direction of the force applied helps but it is a weak link to me. Was thinking about drilling two set screws in to stop it from happening again.
Austin is offline
Old 12-07-2010 | 09:35 AM
Thats what I thought. It seems to be the weak link in the pump.
jswfl09 is offline
