Some MISC parts...mufflers, tailstocks, etc >
Old 10-31-2010 | 06:28 PM
Default Some MISC parts...mufflers, tailstocks, etc
1 Masterlube Preluber 125.00
2 TRS tailstocks complete with couplers and bearing. Great shape, bearings good, no salt junk. 150.00 each
1 Green Tag Borg Warner 72C trans 1:1 ratio. no tailstock. Low Hour used. Good shape. 600.00
2 Pairs of Gaffrig Powertip mufflers. Need good cleaning and polishing. No air pump or lines. 125.00 per pair.
Pair of Labbed 26P maximus props. Some slight nicks on the edges of the blades, but they work great ,and ran perfectly in synch. 1000.00 for the pair. Will not separate the pair..Sorry.
SSM transmission mounts. The ones that bolt to the trans and then to the inner transom plate. Great shape. I have 2 pairs of these. NLA from merc. 150.00 per pair.
TRS Upper case. Upper gears are broke, along with rear inspection cover cracked (due to gears breaking). But case is good, no corrosion. Rear cap is replaceable. 200.00
buyer pays shipping, or local pickup
MILD THUNDER is offline
Old 10-31-2010 | 06:44 PM
Default Fixx
FIXX is offline
Old 11-20-2010 | 10:08 PM
can you send a pic of the tailstocks
[email protected]
thanks
tombone37 is offline
Old 11-20-2010 | 11:41 PM
Default Pre luber
I am interested in the preluber and I am in Rockford can you pm me a phone number to contact you at for some questions. Thanks Eric
Esal is offline
Old 11-21-2010 | 09:40 AM
the trans mounts Pic. please and a little more info on them.
thanks TOM
deadlyhammerhead is offline
Old 11-21-2010 | 11:12 PM
thanks TOM
Basically part #47 and #25 in this diagram. They look like new.
http://www.mercruiserparts.com/Show_...sp?dnbr=809478 93&ivar=images/CRUISER/809478.93/32.png&inbr=2045&bnbr=32&bdesc=TRANSMISSION+COMPON ENTS+%28PLUG+IN%29
Old 12-13-2010 | 11:00 AM
Do you still have the Gaffrig mufflers ?
F357 is offline
Old 12-13-2010 | 11:08 AM
Yes sir.
Old 12-13-2010 | 01:58 PM
I sent you a PM
F357 is offline
Old 12-30-2010 | 04:50 PM
Default update
Just an update I bought the Gill mufflers. They were shiped out very fast and packed well too.
Mild Thunder did not like the bolts and nuts that were on the mufflers so he went out and got new hardware. Now that my friends is service.
F357 is offline
