Mercruiser III vs Anything else >
Old 11-01-2010 | 12:44 PM
Default Mercruiser III vs Anything else
Does anyone know how the old Mercruiser III (not Bravo) transom cutout compare with Bravo drives? I'm wondering if, and when, I replace my Mercruiser III a bravo conversion is possible without major transom work. Any other alternatives? Thanks.
tackledackle is offline
Old 11-01-2010 | 01:15 PM
...powered by single Mark-4 454 built to ~460hp.
Old 11-03-2010 | 07:06 PM
Are you talking about a SSM III? I've never heard of the Mercruiser III. If it is a SSM III, cutout is different. Same goes with the trs. I'm no expert, but thats what i know. Maybe someone here with a little more info.
A.O. Razor is offline
Old 11-04-2010 | 12:19 PM
no, not SSM III... talking about old school Mercruiser III. Been in use on this application for 34 years or so. Getting hard to find parts.
Old 11-04-2010 | 12:25 PM
J-Bonz's Avatar
Pre MR drive? Is it basicly like a alpha drive with a clutch dog in the lower for shifting?
J-Bonz is offline
Old 11-04-2010 | 12:45 PM
Pre-MR - yes I'm pretty sure. No clutch - uses borg warner 73c tranny.
Default Pre-Alpha ?
If your talking about the Pre-Alpha drive like like MR or 888,898 ect, I can tell you first hand that ALL the alpha's and pre alpha's take the same cutout as the bravo. I have an older boat 1980 formula that came with the alpha MR drive and I re-glassed the transom to raise the X-dimension and installed a bravo transom gimbel assm. I used the mercruiser outdrive cut out wich is the same for bravo's you only have to drill 2 more holes to mount a bravo drive.
FORMULAfast is offline
Old 11-04-2010 | 12:49 PM
Ok great info. I'm not sure if it is pre-MR or not. I don't have access to the numbers right now. Thanks!
Old 11-05-2010 | 06:06 AM
Biggus's Avatar
Totally different transom cut out than the Alpha/Bravo cut.
If you don't want to re-rig the boat and the Merc III gimbal is intact, Konrad Marine has a direct bolt-on replacement drive for that unit.
Shoot me an email if interested in more info.
[email protected]
Biggus is offline
Old 11-07-2010 | 02:20 PM
[email protected]
Great. When the time comes - I'll call you. Its still going strong right now, but who knows what tomorrow brings with it's age and all.
Thanks!
