Engine break up >
Engine break up
Engine break up
Old 11-05-2010 | 08:25 AM
Default Engine break up
Im running a basically stock carburated 454 on a 24 pantera.
Boat runs great except sometimes running at wide open throtte or a little under btw 4400-4800 rpm its purring like a kitten then acts like its starving for fuel. it breaks up then chockes itself to anout 3000 rpms then powers back up and so on... Im getting 7 pounds of fuel pressure from manual pump, i even tried flipping on electric pump before it chocks but hasnt helpled.. Any ideas??? Im going to try to recheck float bowl level
pantera232 is offline
Old 11-05-2010 | 08:34 AM
It sounds like your water sep. It will keep getting worse. Are you sure its fuel related? Also check ignition module and coil etc for loose wires.
GTOFFSHORE is offline
