Thermostat Housing
Old 11-07-2010 | 05:36 PM
scottw's Avatar
Default Thermostat Housing
Did Mercury ever make a updated thermostat housing for a Gen. IV 454 Magnum. I have the old style with the poppet balls.
http://s1190.photobucket.com/albums/...tat%20housing/
scottw is offline
Old 11-08-2010 | 01:18 AM
You can make any tstat housing work. You just have to plumb it differently.
Griff is offline
Old 11-08-2010 | 05:49 AM
That style sucks. IMO the old-school two piece job that they used in the early to mid-80's is better than that thing. They have updated it though, a couple of times. There are a ton of aftermarket versions that work pretty well too.
wjb21ndtown is offline
Old 11-08-2010 | 03:28 PM
scottw's Avatar
What would you guys suggest and how should the lines be rigged? Any pictures would be appreciated and would I need to install some type of pressure relief valve of some sorts?
scottw is offline
Old 11-09-2010 | 08:10 AM
Ive been researching doing the same thing to my 1994 454 mag. What ive done is bought the sierra stainless housing (approx. $180) part # 18-1989. Then run a hose from the thermostat to the botom of the manifold on each side, use you existing hoses or you an order new ones that dont have the bend at the end right before they meet the thermostat. They will fit better. Then plug the hole in each riser, you dont run a hose to them anymore. I went to bam marine and looked up a 1995-1996 gen v 454. I believe you have a 1992-1994 gen v 454 like me. You can learn alot just by lookin at the parts schematics on their website. They also sell the riser plugs.
hadleycat is offline
Old 11-09-2010 | 08:50 AM
Raw of closed cooling?
f_inscreenname is offline
Old 11-09-2010 | 08:54 AM
Indy's Avatar
Member #154
Great screen name LOL!!
Reminds me of a clever boat name: effin boat because the owner's wife always said "are you going out on that f'ing boat again" LOLOL
Sorry for the hijack
Indy is offline
Old 11-09-2010 | 06:59 PM
scottw's Avatar
I have a 1990 Gen IV but have the same plan. Thanks for the input.
scottw is offline
Old 11-10-2010 | 07:21 AM
boatman22's Avatar
Can the poppet balls just be taken out?
boatman22 is offline
Old 11-14-2010 | 10:10 PM
Are you looking for something like this?
http://cgi.ebay.com/ebaymotors/Mercr...item1c1687e7a0
