WANTED Injectors '98 model 502 MPI, new or used >
Old 11-07-2010 | 08:36 PM
wstultz's Avatar
Social Distortion
Default WANTED Injectors '98 model 502 MPI, new or used
Where is the best place to get injectors for my 1998 model mercruiser 502mpi's? I don't care if they are new or used from a injector upgrade. If someone has a box full of them in their garage as long as they work. Mine on my starboard engine are toast. I need eight of them.
Thanks,
Wade
wstultz is offline
Old 11-07-2010 | 09:19 PM
Smitty's Avatar
I've got a used set of eight short Merc injectors. They are from a 2000 502 MPI. Not sure what was used in a 98. I took a pic. If they'll work, make me an offer.
Attached Thumbnails WANTED Injectors '98 model 502 MPI, new or used-short-injector.jpg
Smitty is offline
Old 11-07-2010 | 09:22 PM
Default inj.
why are they toast did you have a efi specialist check them? i have a guy that is a big drag race guy here locally that has a 20,000 dollar injector cleaner and he flows them pulses them replaces the screens he can watch them to see if they bleed by under pressure if they all flow the same and it ultrasonic cleans them for only 12.00 per injector chances are thats all you need they are a fortune to replace. if you need more info email me at [email protected]
NorCalracer is offline
Old 11-08-2010 | 06:50 AM
I have a stock set from a 496 with 100 hrs and another set that are bigger...don't know there application. Open to an offer if they will work also!
pachanga is offline
Old 11-08-2010 | 06:58 AM
Airpacker's Avatar
I have a complete take out set from a 2000 500 efi. If they are the same, make me an offer.
Airpacker is offline
Old 11-08-2010 | 09:24 AM
i have a complete set from a 97 415 hp 502,let me know if you can use them.they can be had CHEEP.
mike tkach is offline
Old 11-08-2010 | 09:51 AM
wstultz's Avatar
Social Distortion
They aren't dirty the plastic brackets that attach to them for the plugs are breaking off. Possibly from corrosion? 4 out of the eight have done it so far so i'm going to replace all of them. Thanks for the info though about the cleaner, good to know for future reference.
wstultz is offline
Old 11-08-2010 | 01:06 PM
i have a new set i didn't need 150obo
ridefast77 is offline
