Counter rotating on a single >
Old 11-12-2010 | 09:40 AM
Default Counter rotating on a single
Any advantage of a counter rotating outdrive on a single. Looking at a boat and it has a coutner rotating lower unit. Would it help counter react the engine torque ?
Plus Man is offline
Old 11-12-2010 | 10:08 AM
Too Stroked's Avatar
Some boats use left hand rotation props (Fountain 27' & 29's for instance) for a variety of reasons. Using a counter rotating drive in a single is very unusual. For one thing, it's going to make finding a prop a lot more difficult. Is it original to the boat or did somebody score a cheap drive because it was avaialble?
Too Stroked is offline
Old 11-12-2010 | 10:45 AM
Shore Thing's Avatar
Yes. Counteracting torque is exactly what it is meant to do. The extent to which it helps depends on the hull. When i put bigger power in my velocity, i changed to counter rotating and it made a small improvement at high speeds.
Shore Thing is offline
Old 11-12-2010 | 12:20 PM
T2x's Avatar
T2x
Allergic to Nonsense
Are you referring to duo prop drives?
T2x is offline
Old 11-12-2010 | 12:41 PM
I don't see why it would make finding a prop more difficult. Everyone that makes a RH prop makes a LH, and RHs are more desirable as that's what the majority of singles run. There's tons of LH wheels out there that are left over mates to scavenged RH prop users.
wjb21ndtown is offline
