Flywheel help >
Flywheel help
Flywheel help
Old 11-13-2010 | 03:35 PM
Default Flywheel help
Just bought a top gun and have vibration/harmonics on port engine at higher rpms. I have checked with bravo drive off and still there, feels just like a bad gimble bearing or u joints.went through the top end-heads,springs,valves ect. new cam and lifters,swaped distributers and wires.and all the front pullys. The engine is a gen6 ( 100hrs since out of crate )and i suspect the previos owner may have used the wrong flywheel. casting # is 3973457n can anyone tell me if this is a compatable wheel for an externally balanced 502. I just dont want to go into this engine unless i have to. thanks
Rudd Jr is offline
Old 11-13-2010 | 07:57 PM
Mr Gadgets's Avatar
Charter Member #601
Rudd,
the Gen V and VI use a different balance than the Gen IV, but the bolt pattern is the same and the old flywheel will bolt up. See if you can get your hands on a GM Performance catalog, they show alot of info. Not sure if it will idenify your wheel. But it may. You may be able to find a GM dealer that has one in stock that you could compare your flywheel with.
Hope this helps.
Dick
Mr Gadgets is offline
Old 11-13-2010 | 09:02 PM
That is the wrong flywheel. The one you need is 805.
The 457 flywheel is for Mk IV.
I have a few if you need one.
Eddie
Young Performance is offline
Old 11-13-2010 | 09:26 PM
Here is the one you need casting #: Nodular iron with casting 809-14096805
buy good arp flywheel bolts too and use 271 Red Threadlocker from loc tite on the bolts and torque them to the right spec.
http://www.jegs.com/i/GM+Performance...96987/10002/-1
Rockfish71 is offline
Old 11-14-2010 | 04:54 AM
Thanks for the info, I suspected thats what the problem was. I sure wish I coud have caught it when the motor was out, but at least I dont have to rebuild.
Rudd Jr is offline
Old 11-14-2010 | 07:28 AM
and can't really tell the diff by looking at them either...just balance weight and holes diff.
ezstriper is offline
Old 04-21-2026 | 03:55 PM
1 piece rear main flywheels come in 2 external balances.
Lots of confusion on them...with info saying it's for 454 vs 502 engines. This is incorrect.
The 2x external offset balances are 41.7oz and 42.5oz.
Forged 1 pc cranks 454/502 need: 41.7oz
Cast 1pc cranks 454/502 need: 42.5oz
Note: the balance weight is also in a bit diff location...and not just a weight diff. Not sure how mich of an angle diff it is.
Tartilla is offline
Old 04-21-2026 | 04:53 PM
F-2 Speedy's Avatar
Tartooooga thats a 16 yr old thread
F-2 Speedy is offline
Old 04-21-2026 | 06:04 PM
may be 16 years old but if I were the OP it would probably still be on the stand and needing help
compedgemarine is offline
Old 04-21-2026 | 07:34 PM
F-2 Speedy's Avatar
The OP was last here........ Last Activity: 08-27-2013 12:56 PM..........pretty sure he's moved on
