What carbs to buy >
What carbs to buy
What carbs to buy
Old 11-15-2010 | 01:00 PM
Default What carbs to buy
i have stock blue 500 hp carbs drilled out and are about 920cfm, and need rebuilt my motors are appx 600hp i spin them 5600 with 741 crane cam was thinking of going with dominators what do you all think. looking fo a good idle and more power.
rssteiny is offline
Old 11-15-2010 | 02:53 PM
Tough call. However, I think you should send yours out to pro systems, nickerson, or chuck nuytten, and get them redone if they are beyond a renew kit. Your carbs should be enough to support what you have i.m.o.
MILD THUNDER is offline
Old 11-15-2010 | 07:52 PM
If yours are flowed up to 920fm, then that is plenty. Dominators would be too big and are not needed until you get to 540ci or so. You would lose throttle response with too big of carbs.
Griff is offline
Old 11-15-2010 | 08:06 PM
Did the carb 500hps come with 800cfm holleys or 750?
Pokher Ace is offline
Old 11-15-2010 | 09:01 PM
I have 2 hp 950 that im thinking about selling
dennis r is offline
Old 11-15-2010 | 09:02 PM
I have heard that the 500 came with 800cfm carbs. However, it has a 1-11/16th butterfly base plate. That tells me it is has a 750 CFM. All the 800's that ive worked with had a 1-3/4" butterfly. Now another factor is the venturii diameter and horn angle. All of which plays into the cfm rating.
rssteiny
What carbs to buy
How did you go from stock to 920 cfm?
ckin62 is offline
