wt the best prop for a 272 with 600hp >
Old 11-15-2010 | 02:01 PM
Default wt the best prop for a 272 with 600hp
my buddy got a 272 he put a 502 with 600ponys he has a 150bravo drive he needs to no what all you are runnig ?????? 4blade or 3blade and what kind ???? thanks
bajabob is offline
Old 11-15-2010 | 03:17 PM
Depending on other weight items in the boat, gen/stereo try a 28P B1. I am running similar power with a 26 B1 labbed up to 27. I hit 5400 rpm ~76mph. I will try a 28 when I am not paying off other stuff. I have heard and maybe someone can comment that the 5 blade props are harder on the drive. With a stock Bravo drive and 600Hp patience going to plane and pulling back on the stick when jumping wakes is very important. 2 years for me, so far so good. I have a 25OL.
knockld is offline
Old 11-15-2010 | 09:20 PM
Default 5 blade
I spoke to brett today from b blades, we had this same conversation about my 27 baja boss 509 m3 procharged 730 hp. brett said a 5 blade will be the same as a 4 if you treat it with a little respect. a little gental on the stick, he said it will offer a bit more stearn lift over the 4 blade...
pacalim1965@yaho is offline
Old 11-16-2010 | 12:41 PM
You'll kill the drive with a 5 blade. I would think a 28 4 blade. I turn a 30p at 5800 with mine (830HP)
Definitely needs llift. Mine rides like a flatbottom
kennyo is offline
Old 11-16-2010 | 03:49 PM
Has anyone tried a Hydromotive p4x on their Baja??
Cookin is offline
Old 11-18-2010 | 12:41 PM
Going to this spring. I hear 2-3 mph over B1
kennyo is offline
Old 11-18-2010 | 06:02 PM
I have a 25OL.
What kind of engine or other upgrades have you done to the 25 OL?
Baja_man is offline
Old 11-18-2010 | 06:59 PM
Have you tried a BBLADES Bravo 1?Even though I don't have a BAJA I found out my 2000 26 scs Wellcraft Excalibur has the same hull as the 272.The boat's dry weight is heavier @5000lbs but the x dimension,strakes and pad are the same.Even my dash and cabin look almost identical.
Cookin is offline
Old 11-18-2010 | 07:29 PM
look under the seat it will say BAJA
bajabob is offline
Old 11-18-2010 | 07:56 PM
Cookin is offline
