Installing Stainless Steel Rubrail >
Old 11-15-2010 | 09:08 PM
J-Bonz's Avatar
Default Installing Stainless Steel Rubrail
Anyone have any pointers on installing 1/2" hallow stainless steel rub rail? Any tools out there for bending it around corners in the back and the bow? I do have access to a brake at work but, that is far from the shop I am working on it at.. How do the pros do it?
Thanks,
Jr.
J-Bonz is offline
Old 11-16-2010 | 08:00 PM
J-B,
Not sure it will help you but check the website for Jamestown Distributors, they have a video on installing rub rail. Twice I have replaced the alum. rub rail with rubber insert on my boat and you just bend it around the bow and stern by hand. Lot easier than you think!
Dave
David Stotz is offline
Old 11-16-2010 | 11:08 PM
I very carefully bend it around corners with a rubber mallet. Just give it a few hits with the mallet and it bends pretty easily. If it is concave shaped, the top and bottom are going to flatten out some, but there is no way to stop it. It bends surprisingly easy.
Eddie
Young Performance is offline
Old 11-17-2010 | 07:02 AM
Audiofn's Avatar
Charter Member #232
I do the same as Eddie does. Put a couple layers of painters tape on it to protect the finish.
Put your best foot forward!
Audiofn is offline
Old 11-17-2010 | 10:18 AM
Good call. Forgot to mention that. I also get a new, cheap mallet to install it instead of using a beat up greasy one. I just get a cheapo one.
Eddie
Old 11-17-2010 | 10:41 AM
Throttle Fever's Avatar
X2 plus you can fill it with sand or a light blast media and it will help keep it from crushing or flatting when your forming it. Take a little more time (and the mess) but works pretty good if careful. Pete
Throttle Fever is offline
