Mercrusier sandwich adaptor for Mark IV >
Old 11-17-2010 | 05:09 PM
Default Mercrusier sandwich adaptor for Mark IV
I've been reading through the forums and noticed that several users opt to plug the oil bypass.
I'm assuming to plug the sandwich adaptor on a Mark IV assembly (7.4L 330hp) I would just remove and plug reference # 6 on this diagram http://www.marinepartsexpress.com/merc_sch_fs.html
What type of symptoms would result if this valve was removed or failed?
TwinTurboStroker is offline
Old 11-17-2010 | 05:36 PM
blue thunder's Avatar
Yes, #6. I used an npt pipe tap and put a plug in them after removing the valve. Been working for years. If the plug fell out or the valve failed oil would bypass the cooler and filter all the time. It is a differential pressure valve and needs the resistance to flow through those items.
blue thunder is offline
Old 11-18-2010 | 05:26 PM
Thanks for the clarification.
