850 Holley With mechanic Or electric pump >
Old 11-17-2010 | 05:59 PM
Default 850 Holley With mechanic Or electric pump
Hi everyone,
I'm getting a new 850 CFM for my new 502 crate engine, I'm using the same accessories like the combo raw water pump/fuel pump now should I keep using it or is recommended to use a bigger electric one.
Thank you for you feedback
Eclipse1990 is offline
Old 11-17-2010 | 06:02 PM
I've got a 502/415hp motor with 850 holley. I used the 500HP merc sea pump/fuel pump combo. Works great.
TexomaPowerboater is offline
Old 11-17-2010 | 06:40 PM
Wobble's Avatar
SORE MEMBER
Stock pump will work well with fairly stock motor. If you up the power over 550 something like this is a good upgrade.
http://www.cpperformance.com/p-12460...6-engines.aspx
Wobble is offline
